HTTPRoute¶
The HTTPRoute resource in the Kubernetes Gateway API is used to define and manage routing rules for HTTP traffic within a Kubernetes cluster. HTTPRoute is determined by the Gateway API community. It specifies how HTTP requests should be directed from a Gateway to various backend services based on criteria such as paths and headers.
Key aspects of the HTTPRoute¶
Routing Rules: Defines detailed routing rules for HTTP requests, such as routing based on URL paths, request headers, and query parameters.
Service Mapping: Allows configuring of different HTTP requests to be mapped to different backend services or endpoints within the cluster.
Advanced Features: Supports advanced routing features, including weight-based routing and header-based routing, which are useful for traffic management and canary deployments.
By using HTTPRoute, Kubernetes users can precisely control how HTTP traffic is distributed and handled across their services, enabling flexible and efficient traffic management.
Update service¶
When a backend service is edited, the configuration of the dataplane does not get automatically updated. You must perform these steps in sequence.
Delete the service.
Modify the yaml file of the service.
Reapply the service.
CR Parameters¶
The table below describes the supported HTTPRoute spec parameters.
| Parameter | Description | Implementation Details |
parentRefs.name |
Specifies the name of the parent resources that is associated with HTTPRoute. For example, name of Gateway resource - http-gateway | As per the Gateway API community standard. |
parentRefs.namespace |
Specifies the namespace pf the parent resource that is associated with HTTPRoute. When unspecified, this refers to the local namespace of the Route. | As per the Gateway API community standard. |
parentRefs.port |
Specifies the network port that this HTTProute targets. For example, this targets all listeners listening to specified port from a Gateway resource - 8080 | As per the Gateway API community standard. |
parentRefs.sectionName |
Specifies the section name or category of the parent that is associated with HTTPRoute. For example, listener name of Gateway resource - http | As per the Gateway API community standard. |
rules.backendRefs.name |
Specifies the name of the backend service to which the traffic must be sent. For example, spk-app-http-8000-f5ing-testapp | As per the Gateway API community standard. |
rules.backendRefs.namespace |
Specifies the namespace in which backend service is deployed. When unspecified, this refers to the local namespace of the Route. | As per the Gateway API community standard. |
rules.backendRefs.port |
Specifies the port on which the backend service is listening. For example, 8080 | As per the Gateway API community standard. |
rules.backendRefs.weight |
Specifies the weight for load balancing the traffic between multiple backends. For example, 30 | As per the Gateway API community standard. |
rules.matches.headers.name |
Specifies the name of the HTTP Header to be matched. For example, version | As per the Gateway API community standard. |
rules.matches.headers.value |
Specifies the value of HTTP Header to be matched. For example, one | If each rule has multiple header matches provided then rules need to be ordered in such a way that a rule with largest number of header matches is placed at first index, and a rule with smallest number of header matches is placed at last index. Incoming traffic will always be matched against rules in the order in which they are specified in HTTPRoute CR. |
rules.matches.method |
Specifies HTTP method matcher. When specified, this route will be matched only if the request has the specified method. For example, GET | As per the Gateway API community standard. |
rules.matches.path.type |
Specifies how to match against path value. Supported types are Exact and PathPrefix | If specified type is PathPrefix then rules need to be ordered in such a way that a rule with longest prefix match value is placed at first index, and a rule with least prefix match value is placed at last index. Incoming traffic will always be matched against rules in the order in which they are specified in HTTPRoute CR. |
rules.matches.path.value |
Specifies the value of the HTTP path to match against. For example, /v1/chat/completions | As per the Gateway API community standard. |
Note
You can refer to HTTPRoute for more details.
Hostnames, Filters, Timeouts, Retry, and SessionPersistence parameters in HTTPRoute CR are not supported.
HTTPRoute with HTTP/2:¶
To support HTTP/2, kubernetes service should be configured with appProtocol:kubernetes.io/h2c as shown below,
apiVersion: v1
kind: Service
metadata:
spec:
selector:
app: store
ports:
- protocol: TCP
appProtocol: kubernetes.io/h2c
port: 8080
targetPort: 8080
Note:
If multiple HTTPRoutes are attached to same gateway listener, all the services referred by all the routes from their backendRefs must use same appProtocol. CNE controller will consider only 1st route and its service to get the appProtocol and based on that HTTP/2 will be enabled/disabled.
CNE controller only supports
kubernetes.io/h2cfor appProtocol. It does not supportkubernetes.io/wsandkubernetes.io/wssfor appProtocol.
HTTPRoute CR Status¶
HTTPRoute condition - Accepted
| conditions.status | conditions.reason | description |
| Unknown | Pending | Initial state. Waiting for the controller. |
| True | Accepted | Accepted |
| False | - NoMatchingParent - NotAllowedByListeners - NoMatchingListenerHostname |
No Matching Parents by either Name, Port, or SectionName - Route not allowed by listeners - Route has no matching listener hostname |
HTTPRoute condition - ResolvedRef
| True | ResolvedRefs | References Resolved |
| False | - InvalidKind - BackendNotFound - RefNotPermitted - UnsupportedProtocol |
- BackendRef has invalid kind - UnsupportedProtocol - Referenced resource protocol is not supported |
HTTPRoute condition - PartiallyInvalid
| True | UnsupportedValue | Found both valid and invalid rules |
Note: The descriptions may not be the same in the status section of CR.
Sample CRs¶
This section lists the sample CRs of use cases available to apply GRPCRoute. You must apply GatewayClass CR in the cluster and F5BnkGateway in the namespace, only once.
apiVersion: gateway.networking.k8s.io/v1
kind: GatewayClass
metadata:
spec:
controllerName: "f5.com/default-f5-cne-controller"
description: "F5 BIG-IP Kubernetes Gateway"
apiVersion: k8s.f5net.com/v1
kind: F5BnkGateway
metadata:
namespace: default #same namespace in which f5-cne-controller is deployed
spec:
ingressConfig:
defaultListenerNetworks:
- ipv4BaseCidr: "11.11.11.0/24"
startAddress: "11.11.11.1"
endAddress: "11.11.11.255"
Basic HTTPRoute and Gateway API CRs¶
kind: Gateway
metadata:
namespace: gateway-infra
spec:
infrastructure:
parametersRef:
group: k8s.f5net.com
kind: F5BnkGateway
gatewayClassName: f5-gateway-class
listeners:
- name: http
protocol: HTTP
port: 80
allowedRoutes:
namespaces:
kinds:
- kind: HTTPRoute
kind: HTTPRoute
metadata:
namespace: app-ns
spec:
parentRefs:
- name: f5-http-gateway
sectionName: http
rules:
- backendRefs:
- name: infra-backend-v1
port: 8080
namespace: app-ns
Client-side SSL configs¶
kind: Gateway
metadata:
spec:
infrastructure:
parametersRef:
kind: F5BnkGateway
listeners:
- name: https
protocol: HTTPS
port: 443
tls:
certificateRefs:
- kind: Secret
group: ""
allowedRoutes:
namespaces:
kinds:
- kind: HTTPRoute
kind: HTTPRoute
metadata:
namespace: app-ns
spec:
parentRefs:
sectionName: https
rules:
- backendRefs:
port: 8080
namespace: app-ns
HTTPRoute for Exact URL path matching¶
kind: HTTPRoute
metadata:
spec:
parentRefs:
sectionName: http
rules:
- matches:
- path:
type: Exact
value: /match
backendRefs:
port: 8080
namespace: app-ns
- matches:
- path:
type: Exact
value: /match/exact
backendRefs:
- name: infra-backend-v2
port: 8080
namespace: app-ns
- matches:
- path:
type: Exact
value: /match/exact/one
backendRefs:
- name: infra-backend-v3
port: 8080
namespace: app-ns
HTTPRoute for Prefix URL path matching¶
Note: Rules are placed in the order such that longest path prefix match is at first index.
kind: HTTPRoute
metadata:
spec:
parentRefs:
sectionName: http
rules:
- matches:
- path:
type: PathPrefix
value: /match/prefix/one
backendRefs:
port: 8080
namespace: app-ns
- matches:
- path:
type: PathPrefix
backendRefs:
port: 8080
namespace: app-ns
- matches:
- path:
type: PathPrefix
value: /match/
backendRefs:
port: 8080
namespace: app-ns
HTTPRoute for header matching¶
Note: Rules are arranged such that maximum headers match is at first index.
kind: HTTPRoute
metadata:
spec:
parentRefs:
sectionName: http
rules:
# Matches "version: two" AND "color: orange"
- matches:
- headers:
- name: version
value: two
- name: color
value: orange
backendRefs:
port: 8080
namespace: app-ns
# Matches "color: blue" OR "color: green"
- matches:
- headers:
- name: color
value: blue
- headers:
- name: color
value: green
backendRefs:
port: 8080
namespace: app-ns
# Matches "color: red" OR "color: yellow"
- matches:
- headers:
- name: color
value: red
- headers:
- name: color
value: yellow
backendRefs:
port: 8080
namespace: app-ns
# Matches "version: one"
- matches:
- headers:
- name: version
value: one
backendRefs:
port: 8080
namespace: app-ns
- matches:
- headers:
- name: version
value: two
backendRefs:
port: 8080
namespace: app-ns
HTTPRoute for method matching¶
kind: HTTPRoute
metadata:
spec:
parentRefs:
sectionName: http
rules:
- matches:
- method: POST
backendRefs:
port: 8080
namespace: app-ns
- matches:
- method: GET
backendRefs:
port: 8080
namespace: app-ns
HTTPRoute with method or path or header matching¶
kind: HTTPRoute
metadata:
spec:
parentRefs:
sectionName: http
rules:
# Combinations with core match types.
- matches:
- path:
type: PathPrefix
value: /path1
method: GET
backendRefs:
port: 8080
namespace: app-ns
- matches:
- headers:
- name: version
value: one
method: PUT
backendRefs:
port: 8080
namespace: app-ns
- matches:
- path:
type: PathPrefix
value: /path2
headers:
- name: version
value: two
method: POST
backendRefs:
port: 8080
namespace: app-ns
# Match of the form (cond1 AND cond2) OR (cond3 AND cond4 AND cond5)
- matches:
- path:
type: PathPrefix
value: /path3
method: PATCH
- path:
type: PathPrefix
value: /path4
headers:
- name: version
value: three
method: DELETE
backendRefs:
port: 8080
namespace: app-ns
# Matches for checking precedence.
- matches:
- path:
type: PathPrefix
value: /path5
backendRefs:
port: 8080
namespace: app-ns
- matches:
- method: PATCH
backendRefs:
port: 8080
namespace: app-ns
- matches:
- headers:
- name: version
value: four
backendRefs:
port: 8080
namespace: app-ns
- matches:
- method: POST
backendRefs:
port: 8080
namespace: app-ns
- matches:
- method: GET
backendRefs:
port: 8080
namespace: app-ns
HTTPRoute with weighted traffic distribution¶
kind: HTTPRoute
metadata:
spec:
parentRefs:
sectionName: http
rules:
- backendRefs:
port: 8080
namespace: app-ns
weight: 70
port: 8080
namespace: app-ns
weight: 30
