L4Route
This CR defines how the Layer4 routing should be managed within the Kubernetes cluster, allowing requests to be routed at the transport layer (TCP/UDP). L4Route is created based on the experimental TCPRoute/UDPRoute defined by the Gateway API community.
Update service
When a backend service is edited, the configuration of the dataplane does not get automatically updated. You must perform these steps in sequence.
  1. Delete the service.
  2. Modify the yaml file of the service.
  3. Reapply the service.
CR Parameters
The table below provides the description and implementation details of the supported L4Route spec parameters:
Parameter Description
protocol Specifies the application protocol accepted by the listener. Valid values are TCP or UDP.
parentRefs.name Specifies the name of the referent for the Gateway parent references.
parentRefs.sectionName Specifies the name of a section within the target resource.
rules.backendRefs.name Specifies the name to which the Route should forward the a request to a Kubernetes resource (backend service)
rules.backendRefs.port Specifies the port to which the Route should forward the a request to a Kubernetes resource (backend service)
pvaAccelerationMode Enables the preferred acceleration mode for the Packet Velocity ASIC (PVA). The available values are: full/assisted (default) and disabled
- full/assisted: In this mode, traffic routes through the BF3 DPU, enabling hardware offloading for enhanced performance and efficiency
- disabled: In this mode, traffic routes through TMM, which does not use the DPU’s hardware capabilities
Note: This field is only effective for the BF3 DPU Controller
pvaDynamicClientPkts Specifies the number of client packets before dynamic re-offloading occurs. The default value is 0
pvaDynamicServerPkts Specifies the number of server packets before dynamic re-offloading occurs. The default value is 1
Note: Each gateway listener can support only one L4 route. Additionally, if an L4 route includes multiple backend references, all the associated services must share the same IP family. This means that all services must be either dual stack, IPv4, or IPv6. If the IP families differ, some backend references may not receive traffic properly.
L4Route CR Status
L4Route condition - Accepted
conditions.status conditions.reason description
Unknown Pending Initial state. Waiting for controller
True Accepted Accepted
False - NoMatchingParent
- NotAllowedByListeners
- NoMatchingListenerHostname
- No Matching Parents by either Name, Port, or SectionName
- Route not allowed by listeners
- Route has no matching listener hostname
L4Route condition - ResolvedRef
True ResolvedRefs References Resolved
False - InvalidKind
- BackendNotFound
- RefNotPermitted
- UnsupportedProtocol
- BackendRef has invalid kind
- BackendRef not found
- Referenced resource protocol is not supported
L4Route condition - PartiallyInvalid
True UnsupportedValue Found both valid and invalid rules
Note: Descriptions from the above tables may not exactly match those under the status section of the CR.
Sample CRs
Basic GRPCRoute and Gateway API CRs
apiVersion: gateway.networking.k8s.io/v1
kind: GatewayClass
metadata:
spec:
  controllerName: f5.com/default-f5-cne-controller
  description: F5 BIG-IP Kubernetes Gateway
apiVersion: k8s.f5net.com/v1
kind: F5BnkGateway
metadata:
  namespace: default  #same namespace in which f5-cne-controller is deployed
spec:
  ingressConfig:
    defaultListenerNetworks:
      - name: "default_ipv4"
        ipv4BaseCidr: "11.11.11.0/24"
        startAddress: "11.11.11.1"
        endAddress: "11.11.11.10"
      - name: "default_ipv6"
        ipv6BaseCidr: "2002::11:11:11:100/112"
        startAddress: "2002::11:11:11:101"
        endAddress: "2002::11:11:11:110"
kind: Gateway
metadata:
  namespace: gateway-infra
spec:
  infrastructure:
    parametersRef:
      group: k8s.f5net.com
      kind: F5BnkGateway
  gatewayClassName: f5-gateway-class
  listeners:
    - name: tcp
      protocol: TCP
      port: 8000
      allowedRoutes:
        kinds:
          - kind: L4Route
            group: gateway.k8s.f5net.com
apiVersion: gateway.k8s.f5net.com/v1
kind: L4Route
metadata:
  namespace: app-ns
spec:
  parentRefs:
  - name: f5-l4-gateway
    sectionName: tcp
  rules:
  - backendRefs:
    - name: l4-greeter-server
      port: 80
      namespace: app-ns
L4Routes traffic weight distribution CR
kind: L4Route
metadata:
spec:
  protocol: TCP
  parentRefs:
  - name: my-l4-gateway
    sectionName: tcp
  rules:
  - backendRefs:
    - name: tcp-testapp-rg-0-f5ing-testapp
      port: 8050
      weight: 70
    - name: tcp-testapp-rg-1-f5ing-testapp
      port: 8050
      weight: 30
