Install BIG-IP Next for Kubernetes¶
The BIG-IP Next for Kubernetes is deployed through the application of the BnkGatewayClass CR, which allows users to specify the desired state of the BIG-IP Next for Kubernetes cluster. The F5 Lifecycle Operator (FLO) utilizes this BnkGatewayClass CR as an input file to instantiate the BIG-IP Next for Kubernetes component CRs, which deploy the necessary BIG-IP Next for Kubernetes pods with predefined configurations. At the same time, the IPAM Operator utilizes the IPAM Controller CR, created by FLO, as an input file to deploy the IPAM Controller. For information on the bnkgatewayclass spec parameters featured in this example, or for a comprehensive list of available parameters that a user can use to define the desired state of BIG-IP Next for Kubernetes, see bnkgatewayclass CRD parameters.
Note: By default, the BNKGatewayClass CR deployment will install the product in the
defaultnamespace. However, this approach is not recommended. It is expected that customers provide a non-default tenant namespace when installing the FLO helm-chart. This will ensure that FLO is deployed in the designated user-provided tenant namespace. It is important that the BNKGatewayClass CR is also deployed in the same tenant namespace.
Prerequisites¶
Before you install BIG-IP Next for Kubernetes, ensure that the following prerequisites are met:
Perform helm login and apply FAR secret to pull the artifacts from FAR. For more information, see Artifacts via F5 Artifact Registry (FAR).
Configure cert-manager to create certificates for secure communication between pods, see Cert Manager.
Create self-signed CA secret and clusterissuer, see Cert Manager.
Obtained the JWT for this cluster from your MyF5 account.
Create far-secret in
default,f5-operators,f5-utilsor the namespace where you choose to install the product, see Create FAR secret in namespaces.Create
storageclass, see Storage Class.
Apply BnkGatewayClass CR¶
Create a file named
bnkgatewayclass-cr.yamlwith the following configuration.apiVersion: k8s.f5.com/v1 kind: BNKGatewayClass metadata: labels: app.kubernetes.io/name: f5-lifecycle-operator app.kubernetes.io/managed-by: kustomize name: bnkgatewayclass-sample spec: manifestVersion: "2.0.0-1.7.8-0.3.37" containerPlatform: Generic telemetry: loggingSubsystem: enabled: true metricSubsystem: enabled: true certificate: clusterIssuer: sample-issuer deploymentSize: "Small" image: repository: "repo.f5.com/images" imagePullSecrets: - name: far-secret imagePullPolicy: Always networkAttachments: - sf-external - sf-internal # Features # CSRC Egress pseudoCNI: enabled: true # BGP dynamicRouting: enabled: true # Core dump files coreCollection: enabled: true # AFM firewallACL: enabled: true advanced: demoMode: enabled: false maintenanceMode: enabled: false pseudoCNI: env: - name: "EXCLUDE_CIDR" value: "100.96.8.0/11,100.96.0.0/11" #tmm: # env: # - name: "TMM_CALICO_ROUTER" # value: "default" # - name: "TMM_LOG_LEVEL" # value: "Debug" #firewallACL: # env: # -name: "LOG_LEVEL" # value: "info" #cwc: # env:
Before applying the BIG-IP Next for Kubernetes GatewayClass CR, ensure to modify the
bnkgatewayclass-crwith the correct values for the below listed parameters. For a comprehensive list of available parameters that a user can use to define the desired state of BIG-IP Next for Kubernetes, see bnkgatewayclass CRD parameters.If you opt to use your local registry to pull the artifacts, make sure to update the
repositoryparameter.Update the
imagePullSecrets.namewith actual secret to download artifacts from the registry, see Create FAR secret.Ensure that the
certificate.clusterIssuerparameter inbnkgatewayclass-cr.yamlis properly updated with themetadata.namevalue of the cluster issuer, see Configure Cert Manager.Update the
tmm.env.nameif your cluster has calico CNI.Update the
spec.containerPlatformwithGeneric.Ensure that the Network Attachment Definition is created in the same namespace where you plan to install FLO and BIG-IP Next for Kubernetes, see Multus Network Attachment Definition.
Apply the BnkGatewayClass CR to install BIG-IP Next for Kubernetes.
kubectl apply -f bnkgatewayclass-cr.yaml
The BIG-IP Next for Kubernetes is configured as defined in the BnkGatewayClass custom resource (CR) for the following configurations:
telemetry.loggingSubsystem (Enabled by default):
Enables Fluent Bit sidecar for each component. For more information, see Fluent bit sidecar.
Enables Fluentd deployment.
telemetry.metricSubsystem (Enabled by default):
Enables toda-tmstats container in the TMM pod. For more information, see Distributed Toda for Stats Aggregation.
Enables OpenTelemetry Collector deployment.
Enables Observer-Operator deployment.
Enables Observer and Observer-Receiver StatefulSet.
pseudoCNI (Enabled by default):
Enables CSRC DaemonSet. For more information, see CSRC.
dynamicRouting (Enabled by default):
Enables tmm-routing and tmrouted containers in the TMM pod.
Updates the f5-tmm-dynamic-routing-template ConfigMap for ZebOS configurations. For more information, see ZebOS ConfigMaps.
coreCollection (Enabled by default):
Enables coremond DaemonSet. For more information, see BIG-IP Next for Kubernetes Coremond
firewallACL (Enabled by default):
Enables AFM deployment.
Enables blobd sidecar in the TMM pod.
demoMode:
Requires minimal resources for TMM (single thread, without HugePages and SR-IOV resources).
maintenanceMode:
Allows manual editing of the resources. Disabling this mode will revert all manual changes.
deploymentSize (Small | Medium | Large | Max):
TMM is deployed with deployment size, Small. For more information, see bnkgatewayclass CRD parameters
Check the BIG-IP Next for Kubernetes pods status.
kubectl get pods
Sample Output:
NAME READY STATUS RESTARTS AGE f5-afm-6c67b7847d-mtw5q 2/2 Running 0 102m f5-cne-controller-686995cb98-jw4tp 4/4 Running 0 102m f5-ipam-operator-598996c48b-h7jpm 1/1 Running 0 102m f5-observer-0 2/2 Running 0 102m f5-observer-operator-9fc5cc595-5c5pw 2/2 Running 0 102m f5-observer-receiver-0 2/2 Running 0 102m f5-tmm-zpqld 7/7 Running 0 102m flo-f5-lifecycle-operator-66467b5bc5-zbtqq 2/2 Running 0 102m otel-collector-77bd8dc574-lftjc 1/1 Running 0 102m
Check the BIG-IP Next for Kubernetes pods status running in
f5-utilsnamespace.kubectl get pods -n f5-utils
NAME READY STATUS RESTARTS AGE f5-coremond-2ghll 2/2 Running 0 102m f5-coremond-7vkcp 2/2 Running 0 102m f5-crdconversion-9c57f598b-6wdcw 2/2 Running 0 102m f5-dssm-db-0 3/3 Running 0 102m f5-dssm-db-1 3/3 Running 0 101m f5-dssm-db-2 3/3 Running 0 100m f5-dssm-sentinel-0 3/3 Running 0 102m f5-dssm-sentinel-1 3/3 Running 0 101m f5-dssm-sentinel-2 3/3 Running 0 100m f5-ipam-ctlr-6bcf96585-gwp2j 2/2 Running 0 102m f5-rabbit-6dd774fcd4-gnz8b 2/2 Running 0 102m f5-spk-csrc-tfjh2 2/2 Running 0 102m f5-spk-cwc-76dfc9bd55-4j4cf 3/3 Running 0 102m f5-toda-fluentd-855f54df8c-46x6k 1/1 Running 0 102m
Related Topics
