F5SPKGlobalOptions
The F5SPKGlobalOptions CRD enables you to define multiple different behaviours at the global level (Traffic Management Microkernel (TMM)) on the BlueField-3 (BF3) Data Processing Unit (DPU) using Data Center Operations and Communications Acceleration (DOCA) APIs. These APIs provide secure, high-speed encryption and decryption. The BlueField-3 DPU employs the Advanced Encryption Standard-Galois/Counter Mode (AES-GCM) engine to enhance performance and security for traffic management operations.
Parameters
The table below describes the attributes in spec parameters that can be defined in F5GlobalOptions CR:
Parameters Descriptions Default
ip
object
This parameter is used to configure multiple different behaviours at the global level, such as whether IPv4 options can be accepted.
ip.acceptIPOptions
boolean
Specifies if the IP options are accepted at the global level. false
dnscache
object
This parameter is used to define multiple DNS Cache options at the global level.
dnscache.matchWildcardVip
boolean
Allows Unbound backend service resolution to match to a wildcard Virtual IP (VIP). The VIP must be a fully-wildcard, aka 0.0.0.0/0 or ::/0, and must have a source-address-translation of a snatpool. This is meant to allow SNATing of backend resolutions. false
crypto
object
This parameter is used to enable or disable hardware acceleration.
crypto.hwAccel
boolean
Enables or disables crypto hardware acceleration on the BlueField-3 Data Processing Unit (DPU). true
firewall
object
This parameter is used to configure multiple different behaviors at the global level, such as the default action to apply on traffic.
firewall.defaultAction
string
The default action to apply on traffic not matching any firewall rule in Secure Context or Gateway. The possible enum values are, "", "accept", “reject", "drop".
- accept: Allows traffic matching the rule to continue in software.
- reject: Rejects packets.
- drop: Drops packet silently.
firewall.defaultActionLog
boolean
Indicates that an HSL message must be generated when the defaultAction option is applied. true
firewall.hardwareOffload
boolean
Enables or disables hardware offloading of firewall rules if the platform supports it.
Note:
- Rules with the drop action are only offloaded to Hardware.
- You must specify value in this to overwrite the previously set value.
F5SPKGlobalOptions CR Example
apiVersion: "k8s.f5net.com/v1"
kind: F5SPKGlobalOptions
metadata:
spec:
  firewall:
    defaultAction: reject
    defaultActionLog: True
    hardwareOffload: True
Disabling Crypto Hardware Acceleration on the BlueField-3 DPU
Follow the steps below to disable crypto hardware acceleration on the BlueField-3 DPU:
  1. Copy the F5SPKGlobalOptions example CR below to a YAML file. Set the crypto.hwAccel parameter to false and save:
    In this example, the CR installs to the spk-ingress Project:
     apiVersion: k8s.f5net.com/v1
     metadata:
       namespace: spk-ingress
     spec:
       crypto:
         hwAccel: false
  2. Apply the F5SPKGlobalOptions CR that you have created:
    kubectl apply -f f5-global-options.yaml
The crypto hardware acceleration is now disabled on the BlueField-3 DPU, and a software-based codec will be enabled.
Enabling Crypto Hardware Acceleration on the BlueField-3 DPU
Prerequisites:
To enable crypto hardware acceleration on the BlueField-3 Data Processing Unit (DPU), ensure you have the following:
  1. A BlueField-3 DPU must have a crypto-capable device.
  2. A Scalable Function (SF) must be created on the BlueField-3 DPU.
Follow the steps below to enable ‌crypto hardware acceleration on the BlueField-3 DPU:
  1. Copy the F5SPKGlobalOptions example CR below to a YAML file. Set the crypto.hwAccel parameter to true and save:
     metadata:
       namespace: default
     spec:
       crypto:
         hwAccel: true
The crypto hardware acceleration is now enabled on the BlueField-3 DPU, and a software-based codec will be disabled.
Feedback
Provide feedback to improve this document by emailing spkdocs@f5.com.
