BIG-IP Next for Kubernetes OpenTelemetry Metric DetailsΒΆ
BIG-IP Next for Kubernetes OpenTelemetry collector sends the following statistics:
BDOS UDP DNS Parser
| Metrics | Alias | Description | Aggregation |
| err_bounds | f5.bdos_udp_dns_parser.error.bounds | The number of DNS packets with invalid bounds | Cumulative |
| err_dns_header | f5.bdos_udp_dns_parser.error.dns_header | The number of DNS packets with invalid header | Cumulative |
| err_dns_invalid_packet_size | f5.bdos_udp_dns_parser.error.dns_invalid_packet_size | The number of DNS packets with invalid packet size | Cumulative |
| err_dns_qclass_qtype_missing | f5.bdos_udp_dns_parser.error.dns_qclass_qtype_missing | The number of DNS packets with missing QCLASS and QTYPE fields | Cumulative |
| err_dns_qdcount_zero | f5.bdos_udp_dns_parser.error.dns_qdcount_zero | The number of DNS packets with zero value for QDCOUNT field | Cumulative |
| err_dns_udp_frag_no_l4 | f5.bdos_udp_dns_parser.error.dns_udp_frag_no_l4 | The number of fragmented DNS packets with no UDP header | Cumulative |
| err_dns_udp_incomplete_first_ip_frag | f5.bdos_udp_dns_parser.error.dns_udp_incomplete_first_ip_frag | The number of fragmented DNS packets with no UDP header | Cumulative |
| err_first_qname_compressed | f5.bdos_udp_dns_parser.error.first_qname_compressed | The number of DNS packets with incomplete first fragment (i.e., DNS header and first QD entry) | Cumulative |
| err_max_qname_len_excd | f5.bdos_udp_dns_parser.error.max_qname_len_excd | The number of DNS packets that exceed maximum domain name length of 255 octets | Cumulative |
| err_min_udp_dns_size | f5.bdos_udp_dns_parser.error.min_udp_dns_size | The number of DNS packets that do not have minimum header size | Cumulative |
| err_non_dns_udp | f5.bdos_udp_dns_parser.error.non_dns_udp | The number of DNS packets that are not UDP | Cumulative |
| success | f5.bdos_udp_dns_parser.success | The number of DNS packets that are valid | Cumulative |
DNS cache resolver statistics
| Label | Alias | Description |
| name | f5.dns_cache_resolver.name | The name of the DNS cache resolver |
| Metric | Alias | Description | Aggregation |
| async | f5.dns_cache_resolver.async | The number of asynchronous responses | Cumulative |
| cb_ctx_cnt | f5.dns_cache_resolver.callback_context | The number of callback context entries | Cumulative |
| failure_cf | f5.dns_cache_resolver.connection_failure | Connection failures | Cumulative |
| failure_resolv | f5.dns_cache_resolver.resolution_failure | Internal resolution failures | Cumulative |
| failure_send | f5.dns_cache_resolver.send_failure | Response send failures | Cumulative |
| failure_server | f5.dns_cache_resolver.server_failure | Server failures | Cumulative |
| fwd.queries | f5.dns_cache_resolver.fwd.queries | The number of queries requested of the cache that were forwarded | Cumulative |
| fwd.responses | f5.dns_cache_resolver.fwd.responses | The number of responses answered by the cache via a forwarder | Cumulative |
| key.bytes_allocated | f5.dns_cache_resolver.key.memory | The memory allocated to all entries in DNSSEC key cache | Cumulative |
| key.evictions | f5.dns_cache_resolver.key.evictions | The number of DNSSEC key cache evictions | Cumulative |
| key.evictions_mempressure | f5.dns_cache_resolver.key.evictions_mempressure | The number of DNSSEC key cache evictions during aggressive memory pressure | Cumulative |
| key.evictions_rate | f5.dns_cache_resolver.key.evictions_rate | The number of DNSSEC key cache evictions per second | Cumulative |
| key.hits | f5.dns_cache_resolver.key.hits | The number of DNSSEC key cache hits | Cumulative |
| key.inserts | f5.dns_cache_resolver.key.inserts | The number of DNSSEC key cache inserts | Cumulative |
| key.misses | f5.dns_cache_resolver.key.misses | The number of DNSSEC key cache misses | Cumulative |
| key.modifications_rate | f5.dns_cache_resolver.key.modifications_rate | The number of DNSSEC key cache inserts and updates per second | Cumulative |
| key.updates | f5.dns_cache_resolver.key.updates | The number of DNSSEC key cache updates | Cumulative |
| local.drops | f5.dns_cache_resolver.local.dropped | The number of packets dropped | Cumulative |
| local.queries | f5.dns_cache_resolver.local.queries | The total number of queries | Cumulative |
| local.responses | f5.dns_cache_resolver.local.responses | The total number of responses | Cumulative |
| mesh.client_wait_response | f5.dns_cache_resolver.mesh.client_wait_response | The number of client queries waiting to respond | Cumulative |
| mesh.dns64nodata | f5.dns_cache_resolver.mesh.dns64nodata | The number of NODATA responses to DNS64 queries | Cumulative |
| mesh.dns64reqs | f5.dns_cache_resolver.mesh.dns64reqs | The number of queries sent for DNS64 | Cumulative |
| mesh.dns64xlated | f5.dns_cache_resolver.mesh.dns64xlated | The number of responses where DNS64 AAAA prefix was used to change A records | Cumulative |
| mesh.forever_states | f5.dns_cache_resolver.mesh.forever_states | The number of reply states in the forever list | Cumulative |
| mesh.hits | f5.dns_cache_resolver.mesh.hits | The number of client queries with no nameserver queries | Cumulative |
| mesh.misses | f5.dns_cache_resolver.mesh.misses | The number of client queries with at least one nameserver query | Cumulative |
| mesh.num_reply_states | f5.dns_cache_resolver.mesh.reply_states | The number of mesh states that have replies | Cumulative |
| mesh.prefetch_queries | f5.dns_cache_resolver.mesh.prefetch_queries | The number of prefetch queries | Cumulative |
| mesh.queries_rate | f5.dns_cache_resolver.mesh.queries_rate | Queries per second | Cumulative |
| mesh.replies_sent | f5.dns_cache_resolver.mesh.replies_sent | The number of replies sent | Cumulative |
| mesh.responses | f5.dns_cache_resolver.mesh.responses | The number of responses answered by resolver | Cumulative |
| mesh.serve_expired_answers | f5.dns_cache_resolver.mesh.serve_expired_answers | The number of serve expired answers | Cumulative |
| mesh.stats_dropped | f5.dns_cache_resolver.mesh.dropped | The number of queries dropped without sending | Cumulative |
| mesh.stats_jostled | f5.dns_cache_resolver.mesh.jostled | The number of queries dropped due to no space after sent | Cumulative |
| mesh.tcp_queries | f5.dns_cache_resolver.mesh.tcp_queries | The number of queries sent to nameservers over TCP | Cumulative |
| mesh.tcp_wait_send | f5.dns_cache_resolver.mesh.tcp_wait_send | The number of queries waiting to be sent over TCP | Cumulative |
| mesh.total_callbacks | f5.dns_cache_resolver.mesh.callbacks | The number of times a response or timeout was handled | Cumulative |
| mesh.udp_queries | f5.dns_cache_resolver.mesh.udp_queries | The number of queries sent to nameservers over UDP | Cumulative |
| mesh.udp_wait_send | f5.dns_cache_resolver.mesh.udp_wait_send | The number of queries waiting to be sent over UDP | Cumulative |
| mesh.unwanted_replies | f5.dns_cache_resolver.mesh.unwanted_replies | The number of replies with no query | Cumulative |
| mesh.wait_response | f5.dns_cache_resolver.mesh.wait_response | The number of queries waiting for response | Cumulative |
| msg.bytes_allocated | f5.dns_cache_resolver.msg.memory | The memory allocated to all entries in complete message cache | Cumulative |
| msg.evictions | f5.dns_cache_resolver.msg.evictions | The number of complete message cache evictions | Cumulative |
| msg.evictions_mempressure | f5.dns_cache_resolver.msg.evictions_mempressure | The number of complete message cache evictions during aggressive memory pressure | Cumulative |
| msg.evictions_rate | f5.dns_cache_resolver.msg.evictions_rate | The number of complete message cache evictions per second | Cumulative |
| msg.hits | f5.dns_cache_resolver.msg.hits | The number of complete message cache hits | Cumulative |
| msg.inserts | f5.dns_cache_resolver.msg.inserts | The number of complete message cache inserts | Cumulative |
| msg.misses | f5.dns_cache_resolver.msg.misses | The number of complete message cache misses | Cumulative |
| msg.modifications_rate | f5.dns_cache_resolver.msg.modifications_rate | The number of complete message cache inserts and updates per second | Cumulative |
| msg.updates | f5.dns_cache_resolver.msg.updates | The number of complete message cache updates | Cumulative |
| nameserver.bytes_allocated | f5.dns_cache_resolver.nameserver.memory | The memory allocated to all entries in internet name-server cache | Cumulative |
| nameserver.evictions | f5.dns_cache_resolver.nameserver.evictions | The number of internet name-server evictions | Cumulative |
| nameserver.evictions_mempressure | f5.dns_cache_resolver.nameserver.evictions_mempressure | The number of internet name-server cache evictions during aggressive memory pressure | Cumulative |
| nameserver.evictions_rate | f5.dns_cache_resolver.nameserver.evictions_rate | The number of internet name-server cache evictions per second | Cumulative |
| nameserver.hits | f5.dns_cache_resolver.nameserver.hits | The number of internet name-server cache hits | Cumulative |
| nameserver.inserts | f5.dns_cache_resolver.nameserver.inserts | The number of internet name-server cache inserts | Cumulative |
| nameserver.misses | f5.dns_cache_resolver.nameserver.misses | The number of internet name-server cache misses | Cumulative |
| nameserver.modifications_rate | f5.dns_cache_resolver.nameserver.modifications_rate | The number of internet name-server cache inserts and updates per second | Cumulative |
| nameserver.updates | f5.dns_cache_resolver.nameserver.updates | The number of internet name-server cache updates | Cumulative |
| ns_resp_err.formerr | f5.dns_cache_resolver.nameserver_response_error.formerr | The number of internet name-server cache responses that have FORMERR error code | Cumulative |
| ns_resp_err.memory | f5.dns_cache_resolver.nameserver_response_error.memory | The number of internet name-server cache responses that have out of memory error | Cumulative |
| ns_resp_err.other | f5.dns_cache_resolver.nameserver_response_error.other | The number of internet name-server cache responses that have other errors | Cumulative |
| ns_resp_err.port_v4 | f5.dns_cache_resolver.nameserver_response_error.port_v4 | The number of internet name-server cache responses that have error due to unavailable port to send IPv4 query | Cumulative |
| ns_resp_err.port_v6 | f5.dns_cache_resolver.nameserver_response_error.port_v6 | The number of internet name-server cache responses that have error due to unavailable port to send IPv6 query | Cumulative |
| ns_resp_err.route_v4 | f5.dns_cache_resolver.nameserver_response_error.route_v4 | The number of internet name-server cache responses that have error due to unavailable route to send IPv4 query | Cumulative |
| ns_resp_err.route_v6 | f5.dns_cache_resolver.nameserver_response_error.route_v6 | The number of internet name-server cache responses that have error due to unavailable route to send IPv6 query | Cumulative |
| ns_resp_err.servfail | f5.dns_cache_resolver.nameserver_response_error.servfail | The number of internet name-server cache responses that have SERVFAIL error code | Cumulative |
| ns_resp_err.timeout | f5.dns_cache_resolver.nameserver_response_error.timeout | The number of internet name-server cache responses that have timeout error | Cumulative |
| queries | f5.dns_cache_resolver.queries | The number of queries requested of the cache | Cumulative |
| response_time_async | f5.dns_cache_resolver.response.time_async | The average time taken (EMA) for asynchronous responses, in microseconds | Maximum |
| response_time_sync | f5.dns_cache_resolver.response.time_sync | The average time taken (EMA) for synchronous responses, in microseconds | Maximum |
| responses | f5.dns_cache_resolver.response.count | The number of responses answered by the cache | Cumulative |
| responses_rate | f5.dns_cache_resolver.response.rate | The number of responses answered by the cache per second | Cumulative |
| rpz_rewrites | f5.dns_cache_resolver.response_policy_rewrites | The number of queries rewritten due to response policy | Cumulative |
| rrset.bytes_allocated | f5.dns_cache_resolver.rrset.memory | The memory allocated to all entries in resource record set cache | Cumulative |
| rrset.evictions | f5.dns_cache_resolver.rrset.evictions | The number of resource record set cache evictions | Cumulative |
| rrset.evictions_mempressure | f5.dns_cache_resolver.rrset.evictions_mempressure | The number of resource record set cache evictions during aggressive memory pressure | Cumulative |
| rrset.evictions_rate | f5.dns_cache_resolver.rrset.evictions_rate | The number of resource record set cache evictions per second | Cumulative |
| rrset.hits | f5.dns_cache_resolver.rrset.hits | The number of resource record set cache hits | Cumulative |
| rrset.inserts | f5.dns_cache_resolver.rrset.inserts | The number of resource record set cache inserts | Cumulative |
| rrset.misses | f5.dns_cache_resolver.rrset.misses | The number of resource record set cache misses | Cumulative |
| rrset.modifications_rate | f5.dns_cache_resolver.rrset.modifications_rate | The number of resource record set cache inserts and updates per second | Cumulative |
| rrset.updates | f5.dns_cache_resolver.rrset.updates | The number of resource record set cache updates | Cumulative |
| sec_bogus | f5.dns_cache_resolver.sec.bogus | DNSSEC responses with bogus security status | Cumulative |
| sec_indeterminate | f5.dns_cache_resolver.sec.indeterminate | DNSSEC responses with indeterminate security status | Cumulative |
| sec_insecure | f5.dns_cache_resolver.sec.insecure | DNSSEC responses with insecure security status | Cumulative |
| sec_secure | f5.dns_cache_resolver.sec.secure | DNSSEC responses with secure security status | Cumulative |
| sec_unchecked | f5.dns_cache_resolver.sec.unchecked | DNSSEC responses with unchecked security status | Cumulative |
| sync | f5.dns_cache_resolver.sync | The number of synchronous responses | Cumulative |
| tcp.bytes_in | f5.dns_cache_resolver.tcp.bytes.received | TCP bytes received for resolution | Cumulative |
| tcp.bytes_out | f5.dns_cache_resolver.tcp.bytes.transmitted | TCP bytes sent for resolution | Cumulative |
| tcp.cur_conns | f5.dns_cache_resolver.tcp.connections.current | Current TCP connections for resolution | Instance |
| tcp.max_conns | f5.dns_cache_resolver.tcp.connections.max | Maximum concurrent TCP connections for resolution | Cumulative |
| tcp.pkts_in | f5.dns_cache_resolver.tcp.packets.received | TCP packets received for resolution | Cumulative |
| tcp.pkts_out | f5.dns_cache_resolver.tcp.packets.transmitted | TCP packets sent for resolution | Cumulative |
| tcp.tot_conns | f5.dns_cache_resolver.tcp.connections.count | The number of TCP connections for resolution | Cumulative |
| udp.bytes_in | f5.dns_cache_resolver.udp.bytes.received | UDP bytes received for resolution | Cumulative |
| udp.bytes_out | f5.dns_cache_resolver.udp.bytes.transmitted | UDP bytes sent for resolution | Cumulative |
| udp.cur_conns | f5.dns_cache_resolver.udp.connections.current | Current UDP connections for resolution | Instance |
| udp.max_conns | f5.dns_cache_resolver.udp.connections.max | Maximum UDP connections for resolution | Cumulative |
| udp.pkts_in | f5.dns_cache_resolver.udp.packets.received | UDP packets received for resolution | Cumulative |
| udp.pkts_out | f5.dns_cache_resolver.udp.packets.transmitted | UDP packets sent for resolution | Cumulative |
| udp.tot_conns | f5.dns_cache_resolver.udp.connections.count | The number of UDP connections for resolution | Cumulative |
DNS resolver statistics
| name | f5.dns_resolver.name | The name of the DNS resolver |
| async | f5.dns_resolver.async | The number of asynchronous responses | Cumulative |
| cb_ctx_cnt | f5.dns_resolver.callback_context | The number of callback context entries | Cumulative |
| failure_cf | f5.dns_resolver.connection_failure | Connection failures | Cumulative |
| failure_resolv | f5.dns_resolver.resolution_failure | Internal resolution failures | Cumulative |
| failure_send | f5.dns_resolver.send_failure | Response send failures | Cumulative |
| failure_server | f5.dns_resolver.server_failure | Server failures | Cumulative |
| fwd.queries | f5.dns_resolver.fwd.queries | The number of queries requested that were forwarded | Cumulative |
| fwd.responses | f5.dns_resolver.fwd.responses | The number of responses answered via a forwarder | Cumulative |
| key.bytes_allocated | f5.dns_resolver.key.memory | The memory allocated to all entries in DNSSEC key | Cumulative |
| key.evictions | f5.dns_resolver.key.evictions | The number of DNSSEC key evictions | Cumulative |
| key.evictions_mempressure | f5.dns_resolver.key.evictions_mempressure | The number of DNSSEC key evictions during aggressive memory pressure | Cumulative |
| key.evictions_rate | f5.dns_resolver.key.evictions_rate | The number of DNSSEC key evictions per second | Cumulative |
| key.hits | f5.dns_resolver.key.hits | The number of DNSSEC key hits | Cumulative |
| key.inserts | f5.dns_resolver.key.inserts | The number of DNSSEC key inserts | Cumulative |
| key.misses | f5.dns_resolver.key.misses | The number of DNSSEC key misses | Cumulative |
| key.modifications_rate | f5.dns_resolver.key.modifications_rate | The number of DNSSEC key inserts and updates per second | Cumulative |
| key.updates | f5.dns_resolver.key.updates | The number of DNSSEC key updates | Cumulative |
| local.drops | f5.dns_resolver.local.dropped | The number of packets dropped | Cumulative |
| local.queries | f5.dns_resolver.local.queries | The total number of queries | Cumulative |
| local.responses | f5.dns_resolver.local.responses | The total number of responses | Cumulative |
| mesh.client_wait_response | f5.dns_resolver.mesh.client_wait_response | The number of client queries waiting to respond | Cumulative |
| mesh.detached_states | f5.dns_resolver.mesh.detached_states | The number of detached internal opportunistic queries | Cumulative |
| mesh.dns64nodata | f5.dns_resolver.mesh.dns64nodata | The number of NODATA responses to DNS64 queries | Cumulative |
| mesh.dns64reqs | f5.dns_resolver.mesh.dns64reqs | The number of queries sent for DNS64 | Cumulative |
| mesh.dns64xlated | f5.dns_resolver.mesh.dns64xlated | The number of responses where DNS64 AAAA prefix was used to change A records | Cumulative |
| mesh.forever_states | f5.dns_resolver.mesh.forever_states | The number of reply states in the forever list | Cumulative |
| mesh.hits | f5.dns_resolver.mesh.hits | The number of client queries with no nameserver queries | Cumulative |
| mesh.misses | f5.dns_resolver.mesh.misses | The number of client queries with at least one nameserver query | Cumulative |
| mesh.num_reply_states | f5.dns_resolver.mesh.reply_states | The number of mesh states that have replies | Cumulative |
| mesh.prefetch_queries | f5.dns_resolver.mesh.prefetch_queries | The number of prefetch queries | Cumulative |
| mesh.queries_rate | f5.dns_resolver.mesh.queries_rate | Queries per second | Cumulative |
| mesh.replies_sent | f5.dns_resolver.mesh.replies_sent | The number of replies sent | Cumulative |
| mesh.responses | f5.dns_resolver.mesh.responses | The number of responses answered by resolver | Cumulative |
| mesh.serve_expired_answers | f5.dns_resolver.mesh.serve_expired_answers | The number of serve expired answers | Cumulative |
| mesh.stats_dropped | f5.dns_resolver.mesh.dropped | The number of queries dropped without sending | Cumulative |
| mesh.stats_jostled | f5.dns_resolver.mesh.jostled | The number of queries dropped due to no space after sent | Cumulative |
| mesh.tcp_queries | f5.dns_resolver.mesh.tcp_queries | The number of queries sent to nameservers over TCP | Cumulative |
| mesh.tcp_wait_send | f5.dns_resolver.mesh.tcp_wait_send | The number of queries sent to nameservers over TCP | Cumulative |
| mesh.total_callbacks | f5.dns_resolver.mesh.callbacks | The number of times a response or timeout was handled | Cumulative |
| mesh.udp_queries | f5.dns_resolver.mesh.udp_queries | The number of queries sent to nameservers over UDP | Cumulative |
| mesh.udp_wait_send | f5.dns_resolver.mesh.udp_wait_send | The number of queries waiting to be sent over UDP | Cumulative |
| mesh.unwanted_replies | f5.dns_resolver.mesh.unwanted_replies | The number of replies with no query | Cumulative |
| mesh.wait_response | f5.dns_resolver.mesh.wait_response | The number of queries waiting for response | Cumulative |
| msg.bytes_allocated | f5.dns_resolver.msg.memory | The memory allocated to all entries in complete message cache | Cumulative |
| msg.evictions | f5.dns_resolver.msg.evictions | The number of complete message evictions | Cumulative |
| msg.evictions_mempressure | f5.dns_resolver.msg.evictions_mempressure | The number of complete message evictions during aggressive memory pressure | Cumulative |
| msg.evictions_rate | f5.dns_resolver.msg.evictions_rate | The number of complete message evictions per second | Cumulative |
| msg.hits | f5.dns_resolver.msg.hits | The number of complete message hits | Cumulative |
| msg.inserts | f5.dns_resolver.msg.inserts | The number of complete message inserts | Cumulative |
| msg.misses | f5.dns_resolver.msg.misses | The number of complete message misses | Cumulative |
| msg.modifications_rate | f5.dns_resolver.msg.modifications_rate | The number of complete message inserts and updates per second | Cumulative |
| msg.updates | f5.dns_resolver.msg.updates | The number of complete message updates | Cumulative |
| nameserver.bytes_allocated | f5.dns_resolver.nameserver.memory | The memory allocated to all entries in internet name-server cache | Cumulative |
| nameserver.evictions | f5.dns_resolver.nameserver.evictions | The number of internet name-server evictions | Cumulative |
| nameserver.evictions_mempressure | f5.dns_resolver.nameserver.evictions_mempressure | The number of internet name-server evictions during aggressive memory pressure | Cumulative |
| nameserver.evictions_rate | f5.dns_resolver.nameserver.evictions_rate | The number of internet name-server evictions per second | Cumulative |
| nameserver.hits | f5.dns_resolver.nameserver.hits | The number of internet name-server hits | Cumulative |
| nameserver.inserts | f5.dns_resolver.nameserver.inserts | The number of internet name-server inserts | Cumulative |
| nameserver.misses | f5.dns_resolver.nameserver.misses | The number of internet name-server misses | Cumulative |
| nameserver.modifications_rate | f5.dns_resolver.nameserver.modifications_rate | The number of internet name-server misses | Cumulative |
| nameserver.updates | f5.dns_resolver.nameserver.updates | The number of internet name-server updates | Cumulative |
| ns_resp_err.formerr | f5.dns_resolver.nameserver_response_error.formerr | The number of internet name-server responses that have FORMERR error code | Cumulative |
| ns_resp_err.memory | f5.dns_resolver.nameserver_response_error.memory | The number of internet name-server responses that have out of memory error | Cumulative |
| ns_resp_err.other | f5.dns_resolver.nameserver_response_error.other | The number of internet name-server responses that have other errors | Cumulative |
| ns_resp_err.port_v4 | f5.dns_resolver.nameserver_response_error.port_v4 | The number of internet name-server responses that have error due to unavailable port to send IPv4 query | Cumulative |
| ns_resp_err.port_v6 | f5.dns_resolver.nameserver_response_error.port_v6 | The number of internet name-server responses that have error due to unavailable port to send IPv6 query | Cumulative |
| ns_resp_err.route_v4 | f5.dns_resolver.nameserver_response_error.route_v4 | The number of internet name-server responses that have error due to unavailable route to send IPv4 query | Cumulative |
| ns_resp_err.route_v6 | f5.dns_resolver.nameserver_response_error.route_v6 | The number of internet name-server responses that have error due to unavailable route to send IPv6 query | Cumulative |
| ns_resp_err.servfail | f5.dns_resolver.nameserver_response_error.servfail | The number of internet name-server responses that have SERVFAIL error code | Cumulative |
| ns_resp_err.timeout | f5.dns_resolver.nameserver_response_error.timeout | The number of internet name-server responses that have timeout error | Cumulative |
| queries | f5.dns_resolver.queries | The number of queries requested | Cumulative |
| response_time_async | f5.dns_resolver.response.time_async | The average time taken (EMA) for asynchronous responses, in microseconds | Maximum |
| response_time_sync | f5.dns_resolver.response.time_sync | The average time taken (EMA) for synchronous responses, in microseconds | Maximum |
| responses | f5.dns_resolver.response.count | The number of responses answered | Cumulative |
| responses_rate | f5.dns_resolver.response.rate | The number of responses answered per second | Cumulative |
| rpz_rewrites | f5.dns_resolver.response_policy_rewrites | The number of queries rewritten due to response policy | Cumulative |
| rrset.bytes_allocated | f5.dns_resolver.rrset.memory | The memory allocated to all entries in resource record set cache | Cumulative |
| rrset.evictions | f5.dns_resolver.rrset.evictions | The number of resource record set evictions | Cumulative |
| rrset.evictions_mempressure | f5.dns_resolver.rrset.evictions_mempressure | The number of resource record set evictions during aggressive memory pressure | Cumulative |
| rrset.evictions_rate | f5.dns_resolver.rrset.evictions_rate | The number of resource record set evictions per second | Cumulative |
| rrset.hits | f5.dns_resolver.rrset.hits | The number of resource record set hits | Cumulative |
| rrset.inserts | f5.dns_resolver.rrset.inserts | The number of resource record set inserts | Cumulative |
| rrset.misses | f5.dns_resolver.rrset.misses | The number of resource record set misses | Cumulative |
| rrset.modifications_rate | f5.dns_resolver.rrset.modifications_rate | The number of resource record set inserts and updates per second | Cumulative |
| rrset.updates | f5.dns_resolver.rrset.updates | The number of resource record set updates | Cumulative |
| sec_bogus | f5.dns_resolver.sec.bogus | DNSSEC responses with bogus security status | Cumulative |
| sec_indeterminate | f5.dns_resolver.sec.indeterminate | DNSSEC responses with indeterminate security status | Cumulative |
| sec_insecure | f5.dns_resolver.sec.insecure | DNSSEC responses with insecure security status | Cumulative |
| sec_secure | f5.dns_resolver.sec.secure | DNSSEC responses with secure security status | Cumulative |
| sec_unchecked | f5.dns_resolver.sec.unchecked | DNSSEC responses with unchecked security status | Cumulative |
| sync | f5.dns_resolver.sync | The number of synchronous responses | Cumulative |
| tcp.bytes_in | f5.dns_resolver.tcp.bytes.received | TCP bytes received for resolution | Cumulative |
| tcp.bytes_out | f5.dns_resolver.tcp.bytes.transmitted | TCP bytes sent for resolution | Cumulative |
| tcp.cur_conns | f5.dns_resolver.tcp.connections.current | Current TCP connections for resolution | Instance |
| tcp.max_conns | f5.dns_resolver.tcp.connections.max | Maximum concurrent TCP connections for resolution | Cumulative |
| tcp.pkts_in | f5.dns_resolver.tcp.packets.received | TCP packets received for resolution | Cumulative |
| tcp.pkts_out | f5.dns_resolver.tcp.packets.transmitted | TCP packets sent for resolution | Cumulative |
| tcp.tot_conns | f5.dns_resolver.tcp.connections.count | The number of TCP connections for resolution | Cumulative |
| udp.bytes_in | f5.dns_resolver.udp.bytes.received | UDP bytes received for resolution | Cumulative |
| udp.bytes_out | f5.dns_resolver.udp.bytes.transmitted | UDP bytes sent for resolution | Cumulative |
| udp.cur_conns | f5.dns_resolver.udp.connections.current | Current UDP connections for resolution | Instance |
| udp.max_conns | f5.dns_resolver.udp.connections.max | Maximum UDP connections for resolution | Cumulative |
| udp.pkts_in | f5.dns_resolver.udp.packets.received | UDP packets received for resolution | Cumulative |
| udp.pkts_out | f5.dns_resolver.udp.packets.transmitted | UDP packets sent for resolution | Cumulative |
| udp.tot_conns | f5.dns_resolver.udp.connections.count | The number of UDP connections for resolution | Cumulative |
DNS Service statistics
| name | f5.dns_service.name | The name of the DNS service proxy |
| backlogs | f5.dns_service.backlogs | The number of DNS requests waiting to be processed | Cumulative |
| delay_depth | f5.dns_service.delay_depth | The depth of the delay queue | Cumulative |
| drops | f5.dns_service.dropped | Number of DNS queries dropped | Cumulative |
| fails | f5.dns_service.failed | The number of responses whose return code is SERVFAIL | Cumulative |
| referrals | f5.dns_service.referrals | The number of referral responses | Cumulative |
| refused | f5.dns_service.refused | The number of REFUSED responses returned | Cumulative |
| reqs_a | f5.dns_service.requests.a | The number of A type DNS packets received | Cumulative |
| reqs_aaaa | f5.dns_service.requests.aaaa | The number of AAAA type DNS packets received | Cumulative |
| reqs_ns | f5.dns_service.requests.ns | The number of NS type DNS packets received | Cumulative |
| reqs_other | f5.dns_service.requests.other | The number of all types of DNS packets received that do not fall into any of the specific categories | Cumulative |
| reqs_soa | f5.dns_service.requests.soa | The number of SOA type DNS packets received | Cumulative |
| requests | f5.dns_service.requests.count | The number of DNS requests | Cumulative |
| responses | f5.dns_service.responses.count | The number of DNS responses | Cumulative |
| truncs | f5.dns_service.truncated | The number of DNS responses with truncation flag set | Cumulative |
DOS DNSNXdomain statistics
| context_name | f5.dos_dnsnxdomain.context_name | The context name |
| nxdomaintable_entries | f5.dos_dnsnxdomain.nxdomaintable.entry | The number of NXDOMAIN table entries | Cumulative |
| nxdomaintable_lookup | f5.dos_dnsnxdomain.nxdomaintable.lookup | The number of NXDOMAIN table lookups | Cumulative |
| nxdomaintable_lookupsuccess | f5.dos_dnsnxdomain.nxdomaintable.lookup_success | The number of NXDOMAIN table lookups that succeeded | Cumulative |
DOS statistics
| attack_type | f5.dos.attack_type | The attack type |
| dos_context_type | f5.dos.context_type | The context type |
| context_name | f5.dos.context_name | The context name |
| vector_name | f5.dos.vector_name | The vector name |
| profile_name | f5.dos.profile_name | The profile name |
| protocol_type | f5.dos.protocol_type | The protocol type |
| agg_detected | f5.dos.agg_detected | Aggregate attack detected | Cumulative |
| attack_count | f5.dos.attack_count | The number of attacks detected | Cumulative |
| attack_detected | f5.dos.attack_detected | A flag representing whether or not an attack is currently occurring | Maximum |
| ba_detected | f5.dos.bad_actor.detected | Bad actor attack detected | Maximum |
| ba_drops | f5.dos.bad_actor.dropped.count | The number of packets dropped due to bad actor attack | Cumulative |
| ba_drops_1h | f5.dos.bad_actor.dropped.1h | The number of packets dropped due to bad actor attack in the last one hour | Cumulative |
| ba_drops_1m | f5.dos.bad_actor.dropped.1m | The number of packets dropped due to bad actor attack in the last one minute | Cumulative |
| ba_drops_rate | f5.dos.bad_actor.dropped.rate | The number of packets dropped due to bad actor attack in the last second | Cumulative |
| ba_stats | f5.dos.bad_actor.count | The number of bad actor attacks | Cumulative |
| ba_stats_rate | f5.dos.bad_actor.rate | The number of bad actor attacks in the last second | Cumulative |
| bd_detected | f5.dos.bad_destination.detected | Bad destination attack detected | Maximum |
| bd_drops | f5.dos.bad_destination.dropped.count | The number of packets dropped due to bad destination attack | Cumulative |
| bd_drops_1h | f5.dos.bad_destination.dropped.1h | The number of packets dropped due to bad destination attack in the last one hour | Cumulative |
| bd_drops_1m | f5.dos.bad_destination.dropped.1m | The number of packets dropped due to bad destination attack in the last one minute | Cumulative |
| bd_drops_rate | f5.dos.bad_destination.dropped.rate | The number of packets dropped due to bad destination attack in the last second | Cumulative |
| bd_stats | f5.dos.bad_destination.count | The number of bad destination attacks | Cumulative |
| bd_stats_rate | f5.dos.bad_destination.rate | The number of bad destination attacks in the last second | Cumulative |
| bypass_count | f5.dos.bypass.count | The number of packets bypassed | Cumulative |
| bytes | f5.dos.bytes.count | The number of bytes processed | Cumulative |
| bytes_rate | f5.dos.bytes.rate | The number of bytes processed in the last second | Cumulative |
| detection | f5.dos.detection.threshold | The DoS auto-detection threshold | Cumulative |
| detection_ba | f5.dos.detection.bad_actor_threshold | The bad actor auto-detection threshold | Cumulative |
| detection_bd | f5.dos.detection.bad_destination_threshold | The bad destination auto-detection threshold | Cumulative |
| dropped_bytes | f5.dos.dropped.bytes.count | The number of bytes dropped | Cumulative |
| dropped_bytes_rate | f5.dos.dropped.bytes.rate | The number of bytes dropped in the last second | Cumulative |
| drops | f5.dos.dropped.count | The number of DoS packets dropped | Cumulative |
| drops_1h | f5.dos.dropped.1h | The number of DoS packets dropped in the last hour | Cumulative |
| drops_1m | f5.dos.dropped.1m | The number of DoS packets dropped in the last minute | Cumulative |
| drops_rate | f5.dos.dropped.rate | The number of DoS packets dropped in the last second | Cumulative |
| mitigation_ba | f5.dos.mitigation.bad_actor | The auto mitigation threshold for bad actor | Cumulative |
| mitigation_ba_high | f5.dos.mitigation.bad_actor_high | The high mitigation threshold for bad actor | Cumulative |
| mitigation_ba_low | f5.dos.mitigation.bad_actor_low | The low mitigation threshold for bad actor | Minimum |
| mitigation_bd | f5.dos.mitigation.bad_destination | The auto mitigation threshold for bad destination | Cumulative |
| mitigation_bd_high | f5.dos.mitigation.bad_destination_high | The high mitigation threshold for bad destination | Cumulative |
| mitigation_bd_low | f5.dos.mitigation.bad_destination_low | The low mitigation threshold for bad destination | Minimum |
| mitigation_curr | f5.dos.mitigation.current | The current mitigation threshold | Cumulative |
| mitigation_high | f5.dos.mitigation.high | The high mitigation threshold | Minimum |
| mitigation_low | f5.dos.mitigation.low | The low mitigation threshold | Minimum |
| most_recent_agg_applied_time | f5.dos.most_recent_agg_applied_time | The most recent aggregate attack blocked time | Cumulative |
| most_recent_applied_time | f5.dos.most_recent_applied_time | The most recent attack blocked time | Cumulative |
| most_recent_ba_applied_time | f5.dos.most_recent_bad_actor_applied_time | The most recent bad actor attack blocked time | Cumulative |
| most_recent_bd_applied_time | f5.dos.most_recent_bad_destination_applied_time | The most recent bad destination attack blocked time | Cumulative |
| signature_accuracy | f5.dos.signature_accuracy | The attack signature accuracy | Cumulative |
| stats | f5.dos.stats.count | The number of DoS packets received | Cumulative |
| stats_1h | f5.dos.stats.1h | The number of DoS packets received in the last hour | Cumulative |
| stats_1h_samples | f5.dos.stats.1h_samples | The number of packets received in the last hour | Cumulative |
| stats_1m | f5.dos.stats.1m | The number of DoS packets received in the last minute | Cumulative |
| stats_rate | f5.dos.stats.rate | The number of DoS packets received in the last second | Cumulative |
| wl_count | f5.dos.whitelist.count | The number of DoS whitelist hits | Cumulative |
FW Container statistics
| slot_id | f5.firewall.container.slot_id | The processing group of the firewall rule container |
| form | f5.firewall.container.form | The form of the firewall rule container |
| context_type | f5.firewall.container.context_type | The context type |
| context_name | f5.firewall.container.context_name | The context name |
| policy_type | f5.firewall.container.policy_type | The policy type |
| policy_name | f5.firewall.container.policy_name | The policy name |
| activation_time | f5.firewall.container.activation_time | The time at which the firewall container was activated in the TMM | Minimum |
| commit_duration | f5.firewall.container.commit_duration | The time taken for the commit phase of compilation | Minimum |
| commit_time | f5.firewall.container.commit_time | The time at which the commit phase of compilation started | Minimum |
| container_size_kb | f5.firewall.container.size | The size of the firewall rule container in kilobytes | Maximum |
| insert_duration | f5.firewall.container.insert_duration | The time taken to insert rules into the firewall rule container | Minimum |
| overlap_check_duration | f5.firewall.container.overlap_check_duration | The time taken to perform overlapping check for the firewall rule container | Minimum |
| process_mem_kb | f5.firewall.container.process_memory | The amount of memory used during compilation of the firewall rule container | Maximum |
| remove_duration | f5.firewall.container.remove_duration | The time taken to remove rules from the firewall rule container | Minimum |
| rule_count | f5.firewall.container.rule_count | The number of rules in the firewall rule container | Minimum |
| start_time | f5.firewall.container.start_time | The time at which the firewall rule container compilation started | Minimum |
| total_compile_time | f5.firewall.container.compile_time | The total time taken for firewall rule compilation | Minimum |
FX context statistics
| context_type | f5.firewall.context.context_type | The context type |
| context_name | f5.firewall.context.context_name | The context name |
| policy_type | f5.firewall.context.policy_type | The policy type |
| packets_accept | f5.firewall.context.packets_accept | The number of packets accepted | Cumulative |
| packets_accept_decisively | f5.firewall.context.packets_accept_decisively | The number of packets accepted decisively | Cumulative |
| packets_drop | f5.firewall.context.packets_drop | The number of packets accepted dropped | Cumulative |
| packets_reject | f5.firewall.context.packets_reject | The number of packets accepted rejected | Cumulative |
FX logthrottle statistics
| name | f5.firewall.logthrottle.name | The name of the logger |
| vs_name | f5.firewall.logthrottle.vs_name | The virtual server name |
| category | f5.firewall.current_state.category | The log category |
| logtype | f5.firewall.logthrottle.log_type | The log type |
| cum_dropped | f5.firewall.logthrottle.cumulative_dropped | The cumulative count of events dropped by the logger | Cumulative |
| cum_msgs | f5.firewall.logthrottle.cumulative_messages | The cumulative count of events logged by the logge | Cumulative |
| dropped | f5.firewall.logthrottle.dropped | The number of events dropped by the logger | Cumulative |
| msgs | f5.firewall.logthrottle.messages | The number of events logged by the logger | Cumulative |
CGNAT pool statistics
| name | f5.firewall.lsn_pool.name | The name of the NAT pool |
| active_end_points | f5.firewall.lsn_pool.active_end_points | The number of active endpoints | Cumulative |
| active_hairpin_connections | f5.firewall.lsn_pool.active_hairpin_connections | The number of active hairpin connections | Cumulative |
| active_translations | f5.firewall.lsn_pool.active_translations | The number of active translations | Cumulative |
| backup_pool_translations | f5.firewall.lsn_pool.backup_pool_translations | The number of NAT translations from the backup pool | Cumulative |
| dnat_num_excl_addrs | f5.firewall.lsn_pool.dnat_excl_addrs | The number of entries in exclude address table for DNAT | Cumulative |
| end_points | f5.firewall.lsn_pool.end_points | The integer product of the number of IP addresses and the translation port range | Maximum |
| end_points_high_value | f5.firewall.lsn_pool.end_points_high_value | The double product of the number of IP addresses and the translation port range | Maximum |
| hairpin_connection_failures | f5.firewall.lsn_pool.hairpin_connection_failures | The number of failed hairpin connections | Cumulative |
| hairpin_connection_requests | f5.firewall.lsn_pool.hairpin_connection_requests | The number of hairpin connection requests | Cumulative |
| persistence_mapping_failures | f5.firewall.lsn_pool.persistence_mapping_failures | The number of persistence mapping translation request failures | Cumulative |
| translation_ip_attempts | f5.firewall.lsn_pool.translation_ip_attempts | The number of IPs attempted for translation | Cumulative |
| translation_port_attempts | f5.firewall.lsn_pool.translation_port_attempts | The number of ports attempted for translation | Cumulative |
| translation_request_failures | f5.firewall.lsn_pool.translation_request_failures | The number of translation request failures | Cumulative |
| translation_requests | f5.firewall.lsn_pool.translation_requests | The number of translation requests | Cumulative |
NAT rule statistics
| context_name | f5.firewall.lsn_pool.name | The name of the NAT pool |
| context_type | f5.firewall.nat_rule.context_type | The context type |
| rule_name | f5.firewall.nat_rule.rule_name | The rule name |
| action | f5.firewall.nat_rule.action | The rule action (0 - drop; 1 - reject; 2 - accept; 3 - accept decisively) | Maximum |
| counter | f5.firewall.nat_rule.count | The number of times this NAT rule has been hit | Cumulative |
| last_hit_time | f5.firewall.nat_rule.last_hit_time | The last time this NAT rule has been hit | Maximum |
| micro_rules | f5.firewall.nat_rule.micro_rules | The number of micro-rules | Maximum |
NAT translation statistics
| name | f5.firewall.nat_translation.name | The NAT type name |
| type | f5.firewall.nat_translation.type | The translation type |
| bidirectional_request_failures | f5.firewall.nat_translation.bidirectional_request_failures | The number of bidirectional request failures | Cumulative |
| bidirectional_requests | f5.firewall.nat_translation.bidirectional_requests | The number of bidirectional requests | Cumulative |
| err_address_translation | f5.firewall.nat_translation.error.address_translation | The number of err address translation events | Cumulative |
| err_config_mismatch | f5.firewall.nat_translation.error.config_mismatch | The number of err config mismatch events | Cumulative |
| err_flow_collision | f5.firewall.nat_translation.error.flow_collision | The number of err flow collision events | Cumulative |
| err_memory | f5.firewall.nat_translation.error.memory | The number of err memory events | Cumulative |
| err_port_translation | f5.firewall.nat_translation.error.port_translation | The number of err port translation events | Cumulative |
| subscriber_id_errors | f5.firewall.nat_translation.subscriber_id.errors | The number of subscriber id errors | Cumulative |
| subscriber_id_lookups | f5.firewall.nat_translation.subscriber_id.lookups | The number of subscriber id lookups | Cumulative |
| subscriber_id_not_found | f5.firewall.nat_translation.subscriber_id.not_found | The number of subscriber id not found events | Cumulative |
| translation_request_failures | f5.firewall.nat_translation.translation_request.failures | The number of translation request failures | Cumulative |
| translation_requests | f5.firewall.nat_translation.translation_requests.count | The number of translation requests | Cumulative |
FW rule statistics
| context_name | f5.firewall.rule.context_name | The context name |
| context_type | f5.firewall.rule.context_type | The context type |
| rule_name | f5.firewall.rule.rule_name | The rule name |
| action | f5.firewall.rule.action | The rule action (0 - drop; 1 - reject; 2 - accept; 3 - accept decisively) | Maximum |
| counter | f5.firewall.rule.count | The number of packets matching this rule | Cumulative |
| last_hit_time | f5.firewall.rule.last_hit_time | The last time a packet matched this rule | Maximum |
| micro_rules | f5.firewall.rule.micro_rules | The number of micro-rules | Maximum |
ICMPv4 statistics
| drop | f5.icmp.dropped.count | Total number of ICMP messages dropped | Cumulative |
| drop_limit | f5.icmp.dropped.limit | The number of ICMP messages dropped due to user-specified rate limit | Cumulative |
| drop_mcast | f5.icmp.dropped.mcast | The number of ICMP messages dropped due to multicast address | Cumulative |
| drop_notactive | f5.icmp.dropped.notactive | The number of ICMP messages dropped due to HA inactive state | Cumulative |
| drop_route | f5.icmp.dropped.route | The number of ICMP messages dropped due to no route | Cumulative |
| drop_ttl | f5.icmp.dropped.ttl | The number of ICMP messages dropped due to TTL | Cumulative |
| err | f5.icmp.error.count | The number of other not specified errors | Cumulative |
| err_cksum | f5.icmp.error.checksum | The number of ICMP messages received but determined as having ICMP-specific errors, bad ICMP checksums | Cumulative |
| err_len | f5.icmp.error.length | The number of ICMP messages received but determined as having ICMP-specific errors, bad ICMP bad length | Cumulative |
| err_mem | f5.icmp.error.memory | The number of memory allocation errors in the process | Cumulative |
| err_opt | f5.icmp.error.options | The number of errors in options | Cumulative |
| err_proto | f5.icmp.error.protocol | The number of ICMP messages received but determined as having protocol errors | Cumulative |
| err_rtx | f5.icmp.error.rtx | The number of routing errors | Cumulative |
| forward | f5.icmp.forwarded | The number of ICMP messages forwarded | Cumulative |
| rtx | f5.icmp.rtx | The number of ICMP messages dropped as smurf packets | Cumulative |
| rx | f5.icmp.received | The number of ICMP messages received | Cumulative |
| rxsummismatch | f5.icmp.rxsummismatch | The number of hardware-software checksum mismatches | Cumulative |
| tx | f5.icmp.transmitted | The number of ICMP messages attempted to send | Cumulative |
ICMPv6 statistics
| drop | f5.icmp6.dropped.count | Total number of ICMPv6 messages dropped | Cumulative |
| drop_hlim | f5.icmp6.dropped.hop_limit | Total number of ICMPv6 messages dropped due to hop limit | Cumulative |
| drop_limit | f5.icmp6.dropped.limit | The number of ICMPv6 messages dropped due to user-specified rate limit | Cumulative |
| drop_mcast | f5.icmp6.dropped.mcast | The number of ICMPv6 messages dropped due to multicast IP address | Cumulative |
| drop_notactive | f5.icmp6.dropped.notactive | The number of ICMPv6 messages dropped due to HA inactive state | Cumulative |
| drop_redirect | f5.icmp6.dropped.redirect | The number of ICMPv6 messages dropped due to redirect | Cumulative |
| drop_route | f5.icmp6.dropped.route | The number of ICMPv6 messages dropped due to no route | Cumulative |
| drop_source | f5.icmp6.dropped.source | The number of ICMPv6 messages dropped due to invalid source address | Cumulative |
| err | f5.icmp6.error.count | The number of other not specified errors | Cumulative |
| err_cksum | f5.icmp6.error.checksum | The number of ICMPv6 messages received but determined as having ICMP-specific errors, bad ICMP checksums | Cumulative |
| err_len | f5.icmp6.error.length | The number of ICMPv6 messages received but determined as having ICMP-specific errors, bad ICMP bad length | Cumulative |
| err_mem | f5.icmp6.error.memory | The number of memory allocation errors in the process | Cumulative |
| err_opt | f5.icmp6.error.options | The number of errors in options | Cumulative |
| err_proto | f5.icmp6.error.protocol | The number of ICMPv6 messages received but determined as having protocol errors | Cumulative |
| err_rtx | f5.icmp6.error.rtx | The number of routing errors | Cumulative |
| forward | f5.icmp6.forwarded | The number of ICMPv6 messages forwarded | Cumulative |
| rtx | f5.icmp6.rtx | The number of ICMPv6 messages dropped as smurf packets | Cumulative |
| rx | f5.icmp6.received | The number of ICMPv6 messages received | Cumulative |
| rxsummismatch | f5.icmp6.rxsummismatch | The number of hardware-software checksum mismatches | Cumulative |
| tx | f5.icmp6.transmitted | The number of ICMPv6 messages attempted to send | Cumulative |
L3 interface statistics
| if_index | f5.l3_interface.index | The index of the interface |
| name | f5.l3_interface.name | The name of the L3 interface |
| type | f5.l3_interface.type | The interface type |
| hc_in_broadcast_pkts | f5.l3_interface.received.broadcast | The number of incoming broadcast packets | Cumulative |
| hc_in_multicast_pkts | f5.l3_interface.received.mcast | The number of incoming multicast packets | Cumulative |
| hc_in_octets | f5.l3_interface.received.octets | The number of incoming octets | Cumulative |
| hc_in_ucast_pkts | f5.l3_interface.received.ucast | The number of incoming unicast packets | Cumulative |
| hc_out_broadcast_pkts | f5.l3_interface.transmitted.broadcast | The number of outgoing broadcast packets | Cumulative |
| hc_out_multicast_pkts | f5.l3_interface.transmitted.mcast | The number of outgoing multicast packets | Cumulative |
| hc_out_octets | f5.l3_interface.transmitted.octets | The number of outgoing octets | Cumulative |
| hc_out_ucast_pkts | f5.l3_interface.transmitted.ucast | The number of outgoing unicast packets | Cumulative |
| in_discards | f5.l3_interface.received.discards | The number of incoming packets discarded | Cumulative |
| in_errors | f5.l3_interface.received.errors | The number of incoming error packets | Cumulative |
| in_unknown_protos | f5.l3_interface.received.unknown_protos | The number of incoming unknown proto packets | Cumulative |
| out_discards | f5.l3_interface.transmitted.discards | The number of outgoing packets discarded | Cumulative |
| out_errors | f5.l3_interface.transmitted.errors | The number of outgoing error packets | Cumulative |
| syncookie_tmm_cnt | f5.l3_interface.syncookie_tmm_cnt | The number of SYN cookies | Cumulative |
Device interface statistics
| if_index | f5.interface.index | The index of the interface |
| name | f5.interface.name | The name of the L3 interface |
| counters.bytes_in | system.network.bytes | The number of bytes received on the specified interface | Cumulative |
| counters.bytes_out | system.network.bytes | The number of bytes transmitted out of the specified interface | Cumulative |
| counters.collisions | system.network.collisions | The number of collisions on the specified interface, incremented by the number of collisions experienced during transmissions of a frame | Cumulative |
| counters.drops_in | system.network.dropped | The number of packets dropped on ingress for various reasons on the specified interface | Cumulative |
| counters.drops_out | system.network.dropped | The number of packets aged out or with excessive transmission delays due to multiple deferrals on the specified interface | Cumulative |
| counters.errors_in | system.network.errors | The number of received packets that are either undersized, oversized, or have FCS errors by the specified interface | Cumulative |
| counters.errors_out | system.network.errors | The number of excessive collisions, incremented for each frame that experienced 16 collisions during transmission and was aborted on the specified interface | Cumulative |
| counters.pkts_in | system.network.packets | The number of packets received on this interface | Cumulative |
| counters.pkts_out | system.network.packets | The number of packets transmitted out of the specified interface | Cumulative |
| rx_pkts | f5.interface.received.count | The number of packets received on this interface | Cumulative |
| tx_lost_carrier | f5.interface.transmitted.lost_carrier | The number of times that the carrier sense condition was lost or never asserted when attempting to transmit a frame on a particular interface | Cumulative |
| tx_pkts | f5.interface.transmitted.count | The number of packets transmitted out of the specified interface | Cumulative |
IPv4 statistics
| dropped | f5.ip.dropped | The number of dropped datagrams | Cumulative |
| err_cksum | f5.ip.error.checksum | The number of datagrams discarded due to errors in their IP headers, bad checksums | Cumulative |
| err_frag_mem_limit_reached | f5.ip.error.frag_mem_limit_reached | The number of times the memory limit was reached during IP processing | Cumulative |
| err_len | f5.ip.error.length | The number of IP datagrams discarded due to errors in their IP headers, bad length | Cumulative |
| err_mcast_max_pending_packets | f5.ip.error.mcast_max_pending_packets | The number of multicast packets dropped due to pending queue being full | Cumulative |
| err_mcast_max_pending_routes | f5.ip.error.mcast_max_pending_routes | The number of multicast packets dropped due to pending routing exceeded the max number | Cumulative |
| err_mcast_no_route | f5.ip.error.mcast_no_route | The number of multicast packets dropped due to failure to lookup route | Cumulative |
| err_mcast_route_lookup_timeout | f5.ip.error.mcast_route_lookup_timeout | The number of multicast packets dropped due to timeout while looking up route | Cumulative |
| err_mcast_rpf | f5.ip.error.mcast_rpf | The number of multicast packets dropped due to failed reverse-path-forward (RPF) check | Cumulative |
| err_mcast_wrong_if | f5.ip.error.mcast_wrong_if | The number of multicast packets dropped due to wrong interface | Cumulative |
| err_mem | f5.ip.error.memory | The number of memory allocation errors in the packet process | Cumulative |
| err_opt | f5.ip.error.options | The number of errors in options | Cumulative |
| err_proto | f5.ip.error.protocol | The number of IP datagrams discarded due to errors in their protocols | Cumulative |
| err_reassembled_too_long | f5.ip.error.reassembled_too_long | The number of IP datagrams discarded due to errors of reassembled too long | Cumulative |
| err_rtx | f5.ip.error.rtx | The number of routing errors | Cumulative |
| frag_bytes_limit | f5.ip.frag_bytes.limit | The cumulative fragment byte limit for each TMM | Maximum |
| frag_bytes_used | f5.ip.frag_bytes.usage | The maximum number of bytes used by IP fragments by any TMM | Maximum |
| mcast_rx | f5.ip.received.mcast | The number of received multicast packets | Cumulative |
| mcast_tx | f5.ip.transmitted.mcast | The number of transmitted multicast packets | Cumulative |
| nbr_pbq_full_dropped | f5.ip.nbr_pbq_full_dropped | The number of IP datagrams dropped because the neighbor queue was full | Cumulative |
| nbr_unreachable_dropped | f5.ip.nbr_unreachable_dropped | The number of IP datagrams dropped because the neighbor host or gateway was unreachable | Cumulative |
| pending_frag_pkts | f5.ip.pending_frag_pkts | The number of fragmented packets pending reassembly | Cumulative |
| pending_frags | f5.ip.pending_frags | The number of fragments pending reassembly | Cumulative |
| reassembled | f5.ip.reassembled | The number of IP datagrams successfully reassembled | Cumulative |
| rx | f5.ip.received.count | The number of received datagrams from interfaces | Cumulative |
| rx_frag | f5.ip.received.fragmented | The number of packet fragments received | Cumulative |
| rx_frag_dropped | f5.ip.received.frag_dropped | The number of received packet fragments that were dropped | Cumulative |
| tx | f5.ip.transmitted.count | The number of transmitted datagrams to interfaces | Cumulative |
| tx_frag | f5.ip.transmitted.fragmented | The number of packet fragments transmitted | Cumulative |
| tx_frag_dropped | f5.ip.transmitted.frag_dropped | The number of transmitted packet fragments that were dropped | Cumulative |
IPv6 statistics
| dropped | f5.ip6.dropped | Total number of dropped datagrams | Cumulative |
| err_cksum | f5.ip6.error.checksum | The number of datagrams discarded due to errors in their IP headers, bad checksums | Cumulative |
| err_len | f5.ip6.error.length | The number of IP datagrams discarded due to errors in their IP headers, bad length | Cumulative |
| err_mcast_max_pending_packets | f5.ip6.error.mcast_max_pending_packets | The number of multicast packets dropped due to pending queue being full | Cumulative |
| err_mcast_max_pending_routes | f5.ip6.error.mcast_max_pending_routes | The number of multicast packets dropped due to pending routing exceeded the max number | Cumulative |
| err_mcast_no_route | f5.ip6.error.mcast_no_route | The number of multicast packets dropped due to failure to lookup route | Cumulative |
| err_mcast_route_lookup_timeout | f5.ip6.error.mcast_route_lookup_timeout | The number of multicast packets dropped due to timeout while looking up route | Cumulative |
| err_mcast_rpf | f5.ip6.error.mcast_rpf | The number of multicast packets dropped due to timeout while looking up route | Cumulative |
| err_mcast_wrong_if | f5.ip6.error.mcast_wrong_if | The number of multicast packets dropped due to wrong interface | Cumulative |
| err_mem | f5.ip6.error.memory | The number of memory allocation errors in the packet process | Cumulative |
| err_opt | f5.ip6.error.options | The number of errors in options | Cumulative |
| err_proto | f5.ip6.error.protocol | The number of IP datagrams discarded due to errors in their protocols | Cumulative |
| err_reassembled_too_long | f5.ip6.error.reassembled_too_long | The number of IP datagrams discarded due to errors of reassembled too long | Cumulative |
| err_rtx | f5.ip6.error.rtx | The number of routing errors | Cumulative |
| mcast_rx | f5.ip6.received.mcast | The number of received multicast packets | Cumulative |
| mcast_tx | f5.ip6.transmitted.mcast | The number of transmitted multicast packets | Cumulative |
| nbr_pbq_full_dropped | f5.ip6.nbr_pbq_full_dropped | The number of IP datagrams dropped because the neighbor queue was full | Cumulative |
| nbr_unreachable_dropped | f5.ip6.nbr_unreachable_dropped | The number of IP datagrams dropped because the neighbor host or gateway was unreachable | Cumulative |
| pending_frag_pkts | f5.ip6.pending_frag_pkts | The number of fragmented packets pending reassembly | Cumulative |
| pending_frags | f5.ip6.pending_frags | The number of fragments pending reassembly | Cumulative |
| reassembled | f5.ip6.reassembled | The number of IP datagrams successfully reassembled | Cumulative |
| rx | f5.ip6.received.count | The number of received datagrams from interfaces | Cumulative |
| rx_frag | f5.ip6.received.fragmented | The number of packet fragments received | Cumulative |
| rx_frag_dropped | f5.ip6.received.frag_dropped | The number of received packet fragments that were dropped | Cumulative |
| tx | f5.ip6.transmitted.count | The number of transmitted datagrams to interfaces | Cumulative |
| tx_frag | f5.ip6.transmitted.fragmented | The number of packet fragments transmitted | Cumulative |
| tx_frag_dropped | f5.ip6.transmitted.frag_dropped | The number of transmitted packet fragments that were dropped | Cumulative |
LSN Global statistics
| active_inbound_reservations | f5.lsn_global.active_inbound_reservations | The number of active inbound reservations | Cumulative |
| active_persistence_mappings | f5.lsn_global.active_persistence_mappings | The number of active persistence mappings | Cumulative |
| biglsn_fail_early_accepts | f5.lsn_global.biglsn_fail_early_accepts | The number of inbound entries found in the session DB | Cumulative |
| biglsn_fail_early_rejects | f5.lsn_global.biglsn_fail_early_rejects | The number of inbound entries not found in the session DB | Cumulative |
| biglsn_inbound_entry_not_found | f5.lsn_global.biglsn_inbound_entry_not_found | The number of inbound entries not found in the session DB | Cumulative |
| end_points | f5.lsn_global.end_points | The number of endpoints available in the global LSN pool | Cumulative |
TMM page memory statistics
| tmid | f5.page.tmm | The index of this TMM on the system |
| slot | f5.page.slot | The slot ID of the TMM memory pages |
| pages_avail | f5.page.limit | The count of available memory pages allocated for the TMM | Cumulative |
| pages_used | f5.page.usage | The count of used memory pages within the TMM | Cumulative |
Pool member statistics
| pool_name | f5.pool_member.pool_name | The name of the pool |
| addr | f5.pool_member.ip_address | The IP address of the pool member |
| port | f5.pool_member.port | The port number of the pool member |
| connq.age_edm | f5.pool_member.connq.age_edm | The exponential decaying maximum queue entry age in milliseconds | Maximum |
| connq.age_ema | f5.pool_member.connq.age_ema | The exponential moving average queue entry age in milliseconds | Maximum |
| connq.age_head | f5.pool_member.connq.age_head | The age in milliseconds of the oldest queue entry | Maximum |
| connq.age_max | f5.pool_member.connq.age_max | The maximum queue entry age in milliseconds | Maximum |
| connq.depth | f5.pool_member.connq.depth | The number of connections currently in queue | Cumulative |
| connq.serviced | f5.pool_member.connq.serviced | The number of entries that have been removed from the queue | Cumulative |
| cur_sessions | f5.pool_member.sessions.current | The number of current sessions going through the specified pool member | Instance |
| msg.msg_in | f5.pool_member.msg.received.messages | The number of incoming routed messages to the specified pool member | Cumulative |
| msg.msg_out | f5.pool_member.msg.transmitted.messages | The number of outgoing routed messages to the specified pool member | Cumulative |
| msg.req_in | f5.pool_member.msg.received.requests | The number of routed message incoming requests to the specified pool member | Cumulative |
| msg.req_out | f5.pool_member.msg.transmitted.requests | The number of routed message outgoing requests to the specified pool member | Cumulative |
| msg.resp_in | f5.pool_member.msg.received.responses | The number of routed message incoming responses to the specified pool member | Cumulative |
| msg.resp_out | f5.pool_member.msg.transmitted.responses | The number of routed message outgoing responses to the specified pool member | Cumulative |
| serverside.bytes_in | f5.pool_member.serverside.received.bytes | The number of bytes received by the specified pool member from server-side | Cumulative |
| serverside.bytes_out | f5.pool_member.serverside.transmitted.bytes | The number of bytes sent to server-side from the specified pool member | Cumulative |
| serverside.cur_conns | f5.pool_member.serverside.connections.current | The number of current connections from server-side to the specified pool member | Instance |
| serverside.cur_load | f5.pool_member.serverside.connections.load | The current load from server-side on the specified pool member | Instance |
| serverside.max_conns | f5.pool_member.serverside.connections.max | The maximum number of connections from server-side to the specified pool member | Cumulative |
| serverside.pkts_in | f5.pool_member.serverside.received.packets | The number of packets received by the specified pool member from server-side | Cumulative |
| serverside.pkts_out | f5.pool_member.serverside.transmitted.packets | The number of packets sent to server-side from the specified pool member | Cumulative |
| serverside.tot_conns | f5.pool_member.serverside.connections.count | The number of connections from server-side to the specified pool member | Cumulative |
| tot_requests | f5.pool_member.requests.count | The number of requests going through the specified pool member | Cumulative |
DNS profile statistics
| Label | Alias | Description |
| name | f5.profile_dns.name | The name of the DNS profile |
| vs_name | f5.profile_dns.vs_name | The virtual server name |
| Metric | Alias | Description | Aggregation |
| a_reqs | f5.profile_dns.a_reqs | The number of A query packets received | Cumulative |
| aaaa_reqs | f5.profile_dns.aaaa_reqs | The number of AAAA query packets received | Cumulative |
| any_reqs | f5.profile_dns.any_reqs | The number of ANY type query packets received | Cumulative |
| cname_reqs | f5.profile_dns.cname_reqs | The number of CNAME query packets received | Cumulative |
| dns64fails | f5.profile_dns.dns64fails | The number of unsuccessful AAAA requests | Cumulative |
| dns64reqs | f5.profile_dns.dns64reqs | The number of A requests the system generated and sent | Cumulative |
| dns64trans | f5.profile_dns.dns64trans | The number of A responses translated to AAAA | Cumulative |
| drops | f5.profile_dns.dropped | The number of packets dropped | Cumulative |
| edns0_cc_inserted | f5.profile_dns.edns0_cc_inserted | The number of EDNS0 cache control insertions | Cumulative |
| edns0_cc_responses | f5.profile_dns.edns0_cc_responses | The number of EDNS0 cache control responses | Cumulative |
| edns0_cs_inserted | f5.profile_dns.edns0_cs_inserted | The number of EDNS0 client subnet insertions | Cumulative |
| edns0_cs_queries | f5.profile_dns.edns0_cs_queries | The number of EDNS0 client subnet queries | Cumulative |
| edns0_cs_responses | f5.profile_dns.edns0_cs_responses | The number of EDNS0 client subnet responses | Cumulative |
| fast_dns_allowed | f5.profile_dns.fast_dns_allowed | The number of non-matched queries passing through DNS Rapid Response | Cumulative |
| fast_dns_drops | f5.profile_dns.fast_dns_dropped | The number of non-matching queries dropped by DNS Rapid Response | Cumulative |
| fast_dns_queries | f5.profile_dns.fast_dns_queries | The number of queries handled by DNS Rapid Response | Cumulative |
| fast_dns_resp_bvers | f5.profile_dns.fast_dns_resp_bvers | The number of queries resulting in a BADVERS response by DNS Rapid Response | Cumulative |
| fast_dns_resp_ne | f5.profile_dns.fast_dns_resp_ne | The number of non-matching queries resulting in a No-Data response by DNS Rapid Response | Cumulative |
| fast_dns_resp_nx | f5.profile_dns.fast_dns_resp_nx | The number of non-matching queries resulting in a NXDOMAIN response by DNS Rapid Response | Cumulative |
| fast_dns_resp_rf | f5.profile_dns.fast_dns_resp_rf | The number of non-matching queries resulting in a REFUSED response by DNS Rapid Response | Cumulative |
| fast_dns_resp_tc | f5.profile_dns.fast_dns_resp_tc | The number of non-matching queries resulting in a truncated response by DNS Rapid Response | Cumulative |
| fast_dns_responses | f5.profile_dns.fast_dns_responses | The number of responses returned by DNS Rapid Response | Cumulative |
| gtm_rewrites | f5.profile_dns.gtm_rewrites | The number of responses modified by GTM | Cumulative |
| hdr_aa | f5.profile_dns.hdr_aa | The number of responses with AA bit set | Cumulative |
| hdr_ad | f5.profile_dns.hdr_ad | The number of responses with AD bit set | Cumulative |
| hdr_cd | f5.profile_dns.hdr_cd | The number of queries with CD bit set | Cumulative |
| hdr_edns0 | f5.profile_dns.hdr_edns0 | The number of queries with EDNS0 bit set | Cumulative |
| hdr_ra | f5.profile_dns.hdr_ra | The number of responses with RA bit set | Cumulative |
| hdr_rd | f5.profile_dns.hdr_rd | The number of queries with RD bit set | Cumulative |
| hdr_tc | f5.profile_dns.hdr_tc | The number of responses with TC bit set | Cumulative |
| hints | f5.profile_dns.hints | The number of hint (Root Nameservers) responses sent | Cumulative |
| lic_dns_rate_rejects | f5.profile_dns.lic_dns_rate_rejects | The number of DNS queries rejected due to rate limiter action | Cumulative |
| malformed | f5.profile_dns.malformed | The number of malformed packets received | Cumulative |
| malicious | f5.profile_dns.malicious | The number of malicious packets received | Cumulative |
| mx_reqs | f5.profile_dns.mx_reqs | The number of MX query packets received | Cumulative |
| naptr_reqs | f5.profile_dns.naptr_reqs | The number of NAPTR query packets received | Cumulative |
| noerrors | f5.profile_dns.noerrors | The number of NOERROR responses sent | Cumulative |
| ns_reqs | f5.profile_dns.ns_reqs | The number of NS query packets received | Cumulative |
| nxdomain_override | f5.profile_dns.nxdomain_override | The number of responses whose return code is NOERROR due to NXDOMAIN override | Cumulative |
| op_notify | f5.profile_dns.op_notify | The number of queries whose operation code is NOTIFY | Cumulative |
| op_other | f5.profile_dns.op_other | The number of queries whose operation code is uncategorized | Cumulative |
| op_query | f5.profile_dns.op_query | The number of queries whose operation code is QUERY | Cumulative |
| op_update | f5.profile_dns.op_update | The number of queries whose operation code is UPDATE | Cumulative |
| other_reqs | f5.profile_dns.other_reqs | The number of uncategorized DNS packets received | Cumulative |
| ptr_reqs | f5.profile_dns.ptr_reqs | The number of PTR query packets received | Cumulative |
| queries | f5.profile_dns.queries | The number of DNS queries | Cumulative |
| r_badvers | f5.profile_dns.r_badvers | The number of responses whose return code is BADVERS | Cumulative |
| r_noerror | f5.profile_dns.r_noerror | The number of responses whose return code is NOERROR | Cumulative |
| r_nxdomain | f5.profile_dns.r_nxdomain | The number of responses whose return code is NXDOMAIN | Cumulative |
| r_refused | f5.profile_dns.r_refused | The number of responses whose return code is REFUSED | Cumulative |
| r_servfail | f5.profile_dns.r_servfail | The number of responses whose return code is SERVFAIL | Cumulative |
| rejects | f5.profile_dns.rejects | The number of reject (REFUSED) responses sent | Cumulative |
| responses | f5.profile_dns.responses | The number of DNS responses | Cumulative |
| rps | f5.profile_dns.rps | The average number of DNS responses per second | Cumulative |
| soa_reqs | f5.profile_dns.soa_reqs | The number of SOA query packets received | Cumulative |
| srv_reqs | f5.profile_dns.srv_reqs | The number of SRV query packets received | Cumulative |
| suspends | f5.profile_dns.suspends | The number of TCL suspends | Cumulative |
| tocache | f5.profile_dns.tocache | The number of requests sent to the DNS cache | Cumulative |
| todns | f5.profile_dns.todns | The number of requests sent to backend DNS | Cumulative |
| todnsx | f5.profile_dns.todnsx | The number of requests sent to DNS Express | Cumulative |
| togtm | f5.profile_dns.togtm | The number of requests sent to GTM | Cumulative |
| tozxfrd | f5.profile_dns.tozxfrd | The number of DNS Express notifies | Cumulative |
| txt_reqs | f5.profile_dns.txt_reqs | The number of TXT query packets received | Cumulative |
| zone_axfr | f5.profile_dns.zone_axfr | The number of queries whose question type is AXFR | Cumulative |
| zone_ixfr | f5.profile_dns.zone_ixfr | The number of queries whose question type is IXFR | Cumulative |
Profile FTP statistics
| name | f5.profile_ftp.name | The name of the FTP profile |
| vs_name | f5.profile_ftp.vs_name | The virtual server name |
| active_requests | f5.profile_ftp.active_requests | The number of active transfer requests received | Cumulative |
| download_requests | f5.profile_ftp.download_requests | The number of download requests received | Cumulative |
| ftps_bypasses | f5.profile_ftp.ftps_bypasses | The number of FTP transitions to pass through mode due to SSL bypass | Cumulative |
| ftps_intercepts | f5.profile_ftp.ftps_intercepts | The number of intercepted FTPS connections | Cumulative |
| ftps_resets | f5.profile_ftp.ftps_resets | The number of reset FTP connections due to FTPS policy | Cumulative |
| ftps_sessions | f5.profile_ftp.ftps_sessions | The number of sessions entering explicit FTPS mode | Cumulative |
| login_requests | f5.profile_ftp.login_requests | The number of login requests received | Cumulative |
| passive_requests | f5.profile_ftp.passive_requests | The number of passive transfer requests received | Cumulative |
| passthru_transitions | f5.profile_ftp.passthru_transitions | The number of sessions entering pass through mode | Cumulative |
| upload_requests | f5.profile_ftp.upload_requests | The number of upload requests received | Cumulative |
Profile PPTP statistics
| name | f5.profile_pptp.name | The name of the PPTP profile |
| vs_name | f5.profile_pptp.vs_name | The virtual server name |
| common.active_calls | f5.profile_pptp.active_calls | The number of active PPTP calls | Cumulative |
| common.call_clear_requests | f5.profile_pptp.call_clear_requests | The number of PPTP control messages sent by the server to the client indicating that a particular call is to be disconnected | Cumulative |
| common.call_disconnect_notifies | f5.profile_pptp.call_disconnect_notifies | The number of PPTP Call-Disconnect-Notify control messages sent by the client to the server | Cumulative |
| common.echo_replies | f5.profile_pptp.echo_replies | The number of PPTP control messages sent by either peer of a client-server control connection in response to the receipt of an Echo-Request | Cumulative |
| common.echo_requests | f5.profile_pptp.echo_requests | The number of PPTP control messages sent by either peer of a client-server control connection | Cumulative |
| common.failed_calls | f5.profile_pptp.failed_calls | The number of PPTP calls that failed | Cumulative |
| common.outgoing_call_replies | f5.profile_pptp.outgoing_call_replies | The number of PPTP control messages sent in reply to a received Start-Control-Connection-Request message | Cumulative |
| common.outgoing_call_requests | f5.profile_pptp.outgoing_call_requests | The number of PPTP control messages sent by the server to the client to indicate that an outbound call from the client is to be established | Cumulative |
| common.set_link_info | f5.profile_pptp.set_link_info | The number of PPTP control messages sent by the server to the client to set PPP-negotiated options | Cumulative |
| common.start_replies | f5.profile_pptp.start_replies | The number of PPTP control messages sent in reply to a received Start-Control-Connection-Request message | Cumulative |
| common.start_requests | f5.profile_pptp.start_requests | The number of PPTP control messages sent in reply to a received Start-Control-Connection-Request message | Cumulative |
| common.stop_replies | f5.profile_pptp.stop_replies | The number of PPTP control messages sent by one peer of a client-server control connection upon receipt of a Stop-Control-Connection-Request from the other peer | Cumulative |
| common.stop_requests | f5.profile_pptp.stop_requests | The number of PPTP control messages sent by one peer of a client-server control connection to inform the other peer that the control connection should be closed | Cumulative |
| common.total_calls | f5.profile_pptp.total_calls | The number of PPTP calls served | Cumulative |
| common.wan_error_notifies | f5.profile_pptp.wan_error_notifies | The number of WAN-Error-Notify messages sent by the client to the server to indicate WAN error conditions | Cumulative |
Profile RTSP statistics
Label |
Alias |
Description |
name |
f5.profile_rtsp.name |
The name of the RTSP profile |
vs_name |
f5.profile_rtsp.vs_name |
| num_errors | f5.profile_rtsp.errors | The number of RTSP errors | Cumulative |
| num_interleaved_data | f5.profile_rtsp.interleaved_data | The number of interleaved RTSP data packets | Cumulative |
| num_requests | f5.profile_rtsp.requests | The number of RTSP requests | Cumulative |
| num_responses | f5.profile_rtsp.responses | The number of RTSP responses | Cumulative |
Profile SBI ratelimit statistics
| vs_name | f5.profile_sbi_ratelimit.vs_name | The name of the rate limit profile |
| name | f5.profile_sbi_ratelimit.name | The virtual server name |
| cur_acceptance_rate | f5.profile_sbi_ratelimit.acceptance.rate | The current percentage of SBI requests forwarded to a server that received a successful response code | Instance |
| cur_accepted_responses_per_sec | f5.profile_sbi_ratelimit.acceptance.response_rate | The current number of SBI requests per second forwarded to a server that received a successful response code | Instance |
| cur_bytes_per_sec_egress | f5.profile_sbi_ratelimit.egress.rate | The current number of bytes per second egressed by SBI, after any rate limiting was applied | Instance |
| cur_bytes_per_sec_ingress | f5.profile_sbi_ratelimit.ingress.rate | The current number of bytes per second ingressed to SBI, before any rate limiting was applied | Instance |
| cur_conns_at_50_pct_threshold_egress | f5.profile_sbi_ratelimit.egress.conns_at_50_pct_threshold | The current number of connections whose egress rate exceeds 50 percent of the configured SBI ratelimit threshold | Instance |
| cur_conns_at_50_pct_threshold_ingress | f5.profile_sbi_ratelimit.ingress.conns_at_50_pct_threshold | The current number of connections whose ingress rate exceeds 50 percent of the configured SBI ratelimit threshold | Instance |
| cur_conns_at_75_pct_threshold_egress | f5.profile_sbi_ratelimit.egress.conns_at_75_pct_threshold | The current number of connections whose egress rate exceeds 75 percent of the configured SBI ratelimit threshold | Instance |
| cur_conns_at_75_pct_threshold_ingress | f5.profile_sbi_ratelimit.ingress.conns_at_75_pct_threshold | The current number of connections whose ingress rate exceeds 75 percent of the configured SBI ratelimit threshold | Instance |
| cur_conns_at_90_pct_threshold_egress | f5.profile_sbi_ratelimit.egress.conns_at_90_pct_threshold | The current number of connections whose egress rate exceeds 90 percent of the configured SBI ratelimit threshold | Instance |
| cur_conns_at_90_pct_threshold_ingress | f5.profile_sbi_ratelimit.ingress.conns_at_90_pct_threshold | The current number of connections whose ingress rate exceeds 90 percent of the configured SBI ratelimit threshold | Instance |
Protocol inspection libs state
| blade | f5.protocol_inspection_libs_state.blade | The blade index |
| tmm | f5.protocol_inspection_libs_state.tmm | The TMM index |
| filename | f5.protocol_inspection_libs_state.filename | The name of the protocol inspection library file |
| state | f5.protocol_inspection_libs_state.state | The state of the protocol inspection library |
| flows_active | f5.protocol_inspection_libs_state.flows.active | The number of active flows being inspected | Cumulative |
| flows_processed | f5.protocol_inspection_libs_state.flows.processed | The number of flows inspected | Cumulative |
Protocol inspection statistics
| insp_id | f5.protocol_inspection.insp_id | The protocol inspection identifier |
| vs_name | f5.protocol_inspection.vs_name | The virtual server name |
| prof_name | f5.protocol_inspection.prof_name | The name of the protoctol inspection profile |
| hit_count | f5.protocol_inspection.hit_count | The number of times the inspection was matched | Cumulative |
| last_hit_time | f5.protocol_inspection.last_hit_time | The last time the inspection was matched | Maximum |
RST cause statistics
| rst_cause | f5.rst_cause.cause | The cause for TCP/IP reset (RST) |
| count | f5.rst_cause.count | The count for each TCP/IP reset (RST) cause | Cumulative |
TMM physical memory statistics
| name | f5.tmm.pid | The name of the physical memory |
| avail | f5.tmm_physmem.limit | The amount of memory available for TMM | Cumulative |
| used | f5.tmm_physmem.usage | The amount of memory consumed by TMM | Cumulative |
TMM statistics
| pid | f5.tmm.pid | The TMM process ID |
| cpu | f5.tmm.cpu | The index of CPU on which the specified TMM is running on the system |
| slot_id | f5.tmm.slot_id | The hardware slot in a chassis where a blade is plugged in |
| tot_tmms | f5.tmm.limit | The number of TMMs on the system | Cumulative |
| client_side_traffic.bytes_in | f5.tmm.clientside.received.bytes | The number of bytes received by the system from client-side | Cumulative |
| client_side_traffic.bytes_out | f5.tmm.clientside.transmitted.bytes | The number of bytes sent to server-side from the system | Cumulative |
| client_side_traffic.cur_conns | f5.tmm.clientside.connections.current | The current connections from client-side to the system | Instance |
| client_side_traffic.max_conns | f5.tmm.clientside.connections.max | The maximum connections from client-side to the system | Cumulative |
| client_side_traffic.pkts_in | f5.tmm.clientside.received.packets | The number of packets received by the system from client-side | Cumulative |
| client_side_traffic.pkts_out | f5.tmm.clientside.transmitted.packets | The number of packets sent to client-side from the system | Cumulative |
| cpu_usage_1min | f5.tmm.cpu_utilization.1min | The percentage of time the TMM was busy over the last 1 minute | Cumulative |
| cpu_usage_1sec | f5.tmm.cpu_utilization.1sec | The percentage of time the TMM was busy over the last 1 second | Cumulative |
| cpu_usage_5mins | f5.tmm.cpu_utilization.5mins | The percentage of time the TMM was busy over the last 5 minutes | Cumulative |
| cpu_usage_5secs | f5.tmm.cpu_utilization.5secs | The percentage of time the TMM was busy over the last 5 seconds | Cumulative |
| cpu_usage_15mins | f5.tmm.cpu_utilization.15mins | The percentage of time the TMM was busy over the last 15 minutes | Cumulative |
| cpu_usage_15secs | f5.tmm.cpu_utilization.15secs | The percentage of time the TMM was busy over the last 15 seconds | Cumulative |
| dropped_packets | f5.tmm.dropped | The number of dropped packets | Cumulative |
| memory_total | f5.tmm.memory.limit | The memory available for TMM | Cumulative |
| memory_used | f5.tmm.memory.usage | The memory in use for TMM | Cumulative |
| server_side_traffic.bytes_in | f5.tmm.serverside.received.bytes | The number of bytes received by the system from server-side | Cumulative |
| server_side_traffic.bytes_out | f5.tmm.serverside.transmitted.bytes | The number of bytes sent to server-side from the system | Cumulative |
| server_side_traffic.cur_conns | f5.tmm.serverside.connections.current | The current connections from server-side to the system | Instance |
| server_side_traffic.max_conns | f5.tmm.serverside.connections.max | The maximum connections from client-side to the system | Cumulative |
| server_side_traffic.pkts_in | f5.tmm.serverside.received.packets | The number of packets received by the system from server-side | Cumulative |
| server_side_traffic.pkts_out | f5.tmm.serverside.transmitted.packets | The number of packets sent to server-side from the system | Cumulative |
Virtual server statistics
| name | f5.virtual_server.name | The virtual server name |
| destination | f5.virtual_server.destination | The virtual server destination address |
| source | f5.virtual_server.source | The virtual server source address |
| clientside.bytes_in | f5.virtual_server.clientside.received.bytes | The number of bytes received by the specified virtual server from client-side | Cumulative |
| clientside.bytes_out | f5.virtual_server.clientside.transmitted.bytes | The number of bytes sent to client-side from the specified virtual server | Cumulative |
| clientside.cur_conns | f5.virtual_server.clientside.connections.current | The current connections from client-side to the specified virtual server | Instance |
| clientside.max_conns | f5.virtual_server.clientside.connections.max | The maximum connections from client-side to the specified virtual server | Cumulative |
| clientside.pkts_in | f5.virtual_server.clientside.received.packets | The number of packets received by the specified virtual server from client-side | Cumulative |
| clientside.pkts_out | f5.virtual_server.clientside.transmitted.packets | The number of packets sent to client-side from the specified virtual server | Cumulative |
| clientside.tot_conns | f5.virtual_server.clientside.connections.count | The number of connections from client-side to the specified virtual server | Cumulative |
| msg.req_in | f5.virtual_server.msg.received.requests | The number of incoming requests routed through the specified virtual server | Cumulative |
| msg.req_out | f5.virtual_server.msg.transmitted.requests | The number of outgoing requests routed through the specified virtual server | Cumulative |
| msg.resp_in | f5.virtual_server.msg.received.responses | The number of incoming responses routed through the specified virtual server | Cumulative |
| msg.resp_out | f5.virtual_server.msg.transmitted.responses | The number of outgoing responses routed through the specified virtual server | Cumulative |
| serverside.bytes_in | f5.virtual_server.serverside.received.bytes | The number of bytes received by the specified virtual server from server-side | Cumulative |
| serverside.bytes_out | f5.virtual_server.serverside.transmitted.bytes | The number of bytes sent to server-side from the specified virtual server | Cumulative |
| serverside.cur_conns | f5.virtual_server.serverside.connections.current | The current connections from server-side to the specified virtual server | Instance |
| serverside.max_conns | f5.virtual_server.serverside.connections.max | The maximum connections from server-side to the specified virtual server | Cumulative |
| serverside.pkts_in | f5.virtual_server.serverside.received.packets | The number of packets received by the specified virtual server from server-side | Cumulative |
| serverside.pkts_out | f5.virtual_server.serverside.transmitted.packets | The number of packets sent to server-side from the specified virtual server | Cumulative |
| serverside.tot_conns | f5.virtual_server.serverside.connections.total | Total number of connections from server-side to the specified virtual server | Cumulative |
VLAN member statistics
| vlan_name | f5.vlan_member.vlan_name | The name of the vlan |
| member_name | f5.vlan_member.member_name | The name of the VLAN member |
| clone_pkt_err | f5.vlan_member.clone_packet.error | The number of packet clone errors | Cumulative |
| clone_pkt_ok | f5.vlan_member.clone_packet.ok | The number of successfully cloned packets | Cumulative |
