F5 XC EMEA Workshop > Class 6 - F5 AI Security > Protecting the AI Agent Source |
F5 AI Guardrails insertion¶
In order to insert F5 AI Guardrails into the protection process of our application, we will use the Out-of-Band architecture.
This architecture requires modifying the Orchestrator code. We will simplify it by using a middleware that will demonstrate the concept.
It’s important to note this middleware is community-created and not supported by F5. It can be used for demos, POCs for quick testing, or adopted by the customer.
The repository can be found here https://github.com/sorinboia/f5_ai_guardrails_connector_nginx.
Traffic Flow
- The user sends a prompt to the orchestrator.
- The orchestrator sends the full context to the Middleware.
- The Middleware will extract relevant data from the full context and send it to F5 AI Guardrails for scanning.
- F5 AI Guardrails responds to the Middleware after scanning the data with a verdict of allow/block/redact.
- The Middleware will block or redact if needed; otherwise, the request with the full context will be forwarded to the LLM.
- The LLM sends back the response to the orchestrator through the Middleware.
- The Middleware will extract relevant response data and send it to F5 AI Guardrails for scanning.
- F5 AI Guardrails responds to the orchestrator after scanning the LLM response with a verdict of allow/block/redact.
- The Middleware will block or redact if needed; otherwise, the response will be forwarded to the Orchestrator.
- The orchestrator sends the LLM response to the client.
