Activate BIG-IP Next for Kubernetes License¶
Prerequisites
Ensure that you have:
Installed the BIG-IP Next for Kubernetes software.
Installed the BIG-IP Next for Kubernetes CWC.
Obtained the JWT for this cluster from your MyF5 account.
Collect REST API info¶
Licensing the BIG-IP Next for Kubernetes software requires querying the CWC REST API to determine the cluster’s licensing status, and uploading a valid license. To authenticate the CWC REST API, the SSL/TLS certificates and the IP address of the API interface must first be obtained. Use the steps below to obtain the REST API information.
Note: All requests to the CWC and QKView API require authentication using the Admin Token. For more information on retrieving and using the token, see the Admin Access and API Restrictions.
Create a new directory for the CWC REST API certificates:
mkdir -p $HOME/cwc/cwc_api
Copy each of the certificates into the new directory (see Create CWC REST API certificates section in Create Cluster Wide Controller Certificates):
cp api-server-secrets/ssl/client/certs/client_certificate.pem $HOME/cwc/cwc_api
cp api-server-secrets/ssl/ca/certs/ca_certificate.pem $HOME/cwc/cwc_api
cp api-server-secrets/ssl/client/secrets/client_key.pem $HOME/cwc/cwc_api
Create a bash file with the below code.
CWC_CERT_PATH="${CWC_CERTS:-$HOME/cwc/cwc_api}" NODE=$(kubectl -n f5-utils get pod -l app=cwc -o jsonpath='{.items[0].status.hostIP}') CURL_CMD=( curl --cacert "$CWC_CERT_PATH"/ca_certificate.pem \ --cert "$CWC_CERT_PATH"/client_certificate.pem \ --key "$CWC_CERT_PATH"/client_key.pem \ -H "Authorization: Bearer [admin_token]" \ --resolve f5-spk-cwc.f5-utils:30881:"$NODE" ) "${CURL_CMD[@]}" https://f5-spk-cwc.f5-utils:30881/"$@"
Run the bash script using the file you have created.
./cwc-api.sh status | jq
Sample Output
{ "Status": { "ClusterDetails": { "Name": "My Cluster" }, "LicenseDetails": { "DigitalAssetID": "5c367e83-b6cf-4a28-9899-8a3a98b65460", "EntitlementType": "eval", "LicenseExpiryDate": "2025-02-21T20:01:18Z", "LicenseExpiryInDays": "0" }, "LicenseStatus": { "State": "Verification Complete" } }, "TelemetryStatus": { "NextReport": { "StartDate": "2025-02-22 19:55:43 +0000 UTC", "EndDate": "2025-02-28 19:55:43 +0000 UTC", "State": "Telemetry In Progress" } } }
Obtain the name of the CWC Pod in the cluster:
In this example, the CWC is in the f5-utils Project.
kubectl get pods -n f5-utils | grep f5-spk-cwc
In this example, the CWC Pod is named f5-spk-cwc-86d89c4548-fmwpl.
f5-spk-cwc-86d89c4548-fmwpl 2/2 Running
Obtain the IP address of the node the CWC Pod is scheduled on:
kubectl describe pod f5-spk-cwc-86d89c4548-fmwpl -n f5-utils | grep Node:
In this example, the CWC Pod is running on arm64-sm-3 node with IP address 10.144.47.147.
Node: arm64-sm-3/10.144.47.147Edit the hosts file on your system, or setup DNS resolution mapping the node IP address to the CWC’s hostname:
Important: The CWC hostname is required for SSL/TLS certiicate validation.10.144.47.147 f5-spk-cwc.<project>
10.144.47.147 f5-spk-cwc.f5-utils
License the cluster in Connected Mode¶
Once you choose to install BIG-IP Next for Kubernetes with the
curl --key cwc_api/client_key.pem \
--cert cwc_api/client_certificate.pem \
--cacert cwc_api/ca_certificate.pem \
https://f5-spk-cwc.f5-utils:30881/status | jq
The command output indicates the EntitlementType is paid and the LicenseExpiryDate is 2024-03-05. The LicenseExpiryInDays shows expiration occurs in 362 days.
"Status": {
"ClusterDetails": {
"LicenseDetails": {
"LicenseStatus": {
"NextReport": {
License the cluster in FLP Mode¶
Use the following instructions to license a cluster in FLP Mode:
Install and configure F5 License Proxy (FLP), see Install and configure F5 License Proxy (FLP).
Update
license.licenseserverrootcaparameter with FLP RootCA inflo-value.yaml, see Install F5 Lifecycle Operator. The BNK cluster needs FLP RootCA to trust server cert of F5 License Proxy.Note: Ensure you login to the FLP on VM and execute the below command.
setup --print-ca
Sample Output
Secret 'flp-mtls-secret' exists. CA certificate found, decoding from Base64... -----BEGIN CERTIFICATE----- MIICLzCCAdWgAwIBAgIUA48LLaJoJeOQ9WGYMqGRY2CGfkcwCgYIKoZIzj0EAwIw bTELMAkGA1UEBhMCVVMxEzARBgNVBAgMCldhc2hpbmd0b24xEDAOBgNVBAcMB1Nl YXR0bGAgEGCCqGSM49AwEHA0IABFWNOAU5ieEIasdsfNUfnkRajgsdySjyhmPnbat -----END CERTIFICATE-----
Set the
license.operationModetof5licenseproxyinflo-value.yaml, see Install F5 Lifecycle Operator.
