Install F5 Lifecycle Operator
F5 Lifecycle Operator (FLO) is seamlessly installed by using Helm with the values override file flo-value.yaml file, which includes all essential configurations for the successful installation of FLO and the necessary resources to configure BIG-IP Next for Kubernetes. During the FLO Helm installation, the IPAM operator, BnkGatewayClass custom resource definition (CRD), and BIG-IP Next for Kubernetes component CRDs are installed along with FLO. The IPAM Operator, in collaboration with the F5 IPAM Controller (FIC), manages the dual-stack IP addresses (IPv4 and IPv6) for Gateway resources. For more information, see F5 IPAM Controller for Gateway API.
Note: By default, the BNKGatewayClass CR deployment will install the product in the default namespace. However, this approach is not recommended. It is expected that customers provide a non-default tenant namespace when installing the FLO helm-chart. This will ensure that FLO is deployed in the designated user-provided tenant namespace. It is important that the BNKGatewayClass CR is also deployed in the same tenant namespace.
Prerequisites
Before you install FLO, ensure that the following prerequisites are met:
Install the F5 Lifecycle Operator
For information on the F5 Lifecycle Operator parameters featured in this example, or for a comprehensive list of available parameters, see F5 Lifecycle Operator Parameters.
  1. Create a flo-values.yaml  file with the contents below.
    vi flo-values.yaml
    global:
      imagePullSecrets:
        - name: far-secret
      certmgr:
        clusterIssuer: <Name of the ClusterIssuer>
    image:
      repository: repo.f5.com/images
      pullPolicy: Always
    namespace: "f5-operators"
    fluentbit_sidecar:
      enabled: true
      image:
    f5-ipam-operator:
      image:
        pullPolicy: IfNotPresent
      nameOverride: "f5-ipam-operator"
      fullnameOverride: "f5-ipam-operator"
    license:
      jwt: " "
  2. Before you perform the Helm installation for FLO, ensure that you update the flo-value.yaml file with the correct values.
    Note: For information on the FLO Values spec parameters featured in this example, or for a comprehensive list of parameters, see F5 Lifecycle Operator (FLO).
    • Update the namespace details according to your planned configuration.
      Note: Ensure that the f5-ipam-operator.namespace parameter is updated to match the namespace used to install the FLO helm chart.
    • Update the license.jwt with the actual JWT.
    • Update the imagePullSecrets.name with the actual secret to download artifacts from the registry, see Create FAR secret.
    • Ensure that the global.certmgr.clusterIssuer parameter in flo-value.yaml is properly updated with the metadata.name value of the cluster issuer, see Configure Cert Manager.
    • Update the below licensing parameters with the specified values to successfully license the cluster in connected mode:
      • teemCertUrl: https://product.apis.f5.com/ee/v1
      • teemEntitlementUrl: https://product-s.apis.f5.com/ee/v1
      • teemInitialConfigUrl: https://product-s.apis.f5.com/ee/v1.
    • By default, BIG-IP Next for Kubernetes clusters are licensed in connected mode. If you want to license the clusters in FLP mode, set:
      • license.operationMode to f5licenseproxy.
      • license.licenseserverrootca with FLP RootCA. See License the cluster in FLP Mode.
      • teemCertUrl to https://<FLP HostName>:30001/license-proxy/v1 and update the FLP HostName according to your configuration.
      • teemEntitlementUrl to https://<FLP HostName>:30001/license-proxy/v1 and update the FLP HostName according to your configuration.
      • teemInitialConfigUrl to https://<FLP HostName>:30001/license-proxy/v1 and update the FLP HostName according to your configuration.
  3. Install the F5 Lifecycle Operator.
    helm install flo oci://repo.f5.com/charts/f5-lifecycle-operator --version <<FLO_VERSION>> -f flo-values.yaml --namespace <<namespace>>
    In the below example, charts/f5-lifecycle-operator is the path for pulling f5-lifecycle-operator Helm chart and its version is v1.7.8-0.3.37 as retrieved from the bnk-manifest-2.0.0-1.7.8-0.3.37.yaml file.
    helm install flo oci://repo.f5.com/charts/f5-lifecycle-operator --version v1.7.8-0.3.37 -f flo-values.yaml --namespace f5-operators
  4. Download the JWKS cpcl-key-cm ConfigMap here and install the cpcl-key.yaml in the CWC namespace.
    kubectl apply -f cpcl-key.yaml --namespace f5-utils
  5. Check the FLO and F5 IPAM Operator pods status.
    kubectl get pods
    Sample Output:
    NAME                                         READY   STATUS    RESTARTS   AGE
    f5-ipam-operator-75977bb4c6-zhpf7            1/1     Running   0          17s
    flo-f5-lifecycle-operator-6c86fcf6f5-rw8t6   2/2     Running   0          17s
    The FLO and F5 IPAM Controller are successfully installed and running.
  6. Check the BNKGatewayClass CRD and BIG-IP Next for Kubernetes component CRDs.
    NOTE: The BNKGatewayClass CRD and BIG-IP Next for Kubernetes component CRDs will remain in the cluster after the Helm uninstallation of FLO.
    kubectl get crd | grep k8s.f5.com
    Sample Output:
    afms.k8s.f5.com                                  2025-03-18T00:14:41Z
    bnkgatewayclasses.k8s.f5.com                     2025-03-18T00:14:41Z
    coremonds.k8s.f5.com                             2025-03-18T00:14:41Z
    crdconversions.k8s.f5.com                        2025-03-18T00:14:41Z
    csrcs.k8s.f5.com                                 2025-03-18T00:14:41Z
    cwcs.k8s.f5.com                                  2025-03-18T00:14:41Z
    dssms.k8s.f5.com                                 2025-03-18T00:14:41Z
    f5ingresses.k8s.f5.com                           2025-03-18T00:14:41Z
    f5tmms.k8s.f5.com                                2025-03-18T00:14:41Z
    fluentds.k8s.f5.com                              2025-03-18T00:14:41Z
    ipamoperators.k8s.f5.com                         2025-03-18T00:14:41Z
    nodelabelers.k8s.f5.com                          2025-03-18T00:14:41Z
    observers.k8s.f5.com                             2025-03-18T00:14:41Z
    rabbitmqs.k8s.f5.com                             2025-03-18T00:14:41Z
Related Topics
