F5 Application Delivery Controller Solutions > BIG-IP® Local Traffic Manager (LTM) - Getting Started Source | Edit on
Lab 7: Support and Troubleshooting¶
In this lab, you will review your BIG-IP using iHealth and perform some basic troubleshooting commands
Objective:
Collect a QKView and upload it to http://ihealth.f5.com and review the results
Perform a TCPDump to watch traffic flow
Obtain web page information via Curl
Archive the current configuration and perform a health check using a QKview¶
Obtain a QKView. Go to System >> Support
Click New Support Snapshot
Note
If you have an iHealth account, you can choose to use the Generate and Upload QKview to iHealth option as long as your management port has Internet access. For this exercise, we will skip this.
From the drop-down, select Generate QKview
Select Download and download the QKView to your PC
Note
If you leave the Support page and return you will still the Support Snapshot screen. You CANNOT create another QKView or TCP Dump until the QKView is deleted.
Import the QKView into iHealth.
Go to http://ihealth.f5.com. If you don’t have an account, now is the time to create one and then skip to the next section “Troubleshoot using TCPDump or Curl” because it will take time for your account set up.
Select the Upload button and upload the QKView file you download from your BIG-IP
Once the file is uploaded, you can click on the hostname to view you the heuristics
Note the Diagnostics. Go to Diagnostics >> Critical on the side-bar.
Example: The configuration contains user accounts with insecure passwords is because we are using default passwords
Select Network >> Virtual Servers, then click on the small white triangles to expand the view or go to Pools, then Pool Members to continue to expand the view.
This is a little more detailed than Local Traffic >> Network Map
If you want to see some interesting CLI commands, go to Commands >> Standard and expand tmsh then LTM and click on show /ltm virtual toward the bottom
Under Files >> config you can view the bigip.conf file and see the command lines you used for you build
All of the log files are here too
Feel free to just poke around
Troubleshoot using TCPDump or Curl.¶
Go to your www_vs (10.1.10.100) virtual server and set Source Address Translation to None.
Now browse the web site. You will not be able to access it even though the status of the virtual is available.
Because the BIG-IP is not the server’s default gateway of the servers their response goes around the BIG-IP.
The web administrator tells you everything is fine as far as he can see and thinks the issue is with the BIG-IP, because they ALWAYS think the issue is with the BIG-IP
You begin by debugging the client connections to the web servers through the BIG-IP using TCPDump
SSH to the management port of your BIG-IP.
Attention
Remember the BIG-IP is a full proxy. You will need two dumps and therefore two SSH windows for the client-side connection and the server-side connection.
First let’s see if we are hitting the virtual server. At the Linux CLI prompt:
tcpdump –i <client vlan name> host –X –s128 10.1.10.100 and port 80
This is a little overkill, but a good example of syntax. We will only look at traffic headed for the virtual server. We will see the first 128 bytes (-s128) in ASCII (-X).
Go to your browser and attempt to access the virtual server. You should see something like this:
17:38:40.051122 IP 10.1.10.1.43932 > 10.1.10.245.http: S 522853636:522853636(0) win 8192 <mss 1460,nop,wscale 2,nop,nop,sackOK>
0x0000: 0ffe 0800 4500 0034 0a40 4000 4006 0699 ....E..4.@@.@...
0x0010: 0a80 0a01 0a80 0aeb ab9c 0050 1f2a 1d04 ...........P.*..
0x0020: 0000 0000 8002 2000 3d10 0000 0204 05b4 ........=.......
0x0030: 0103 0302 0101 0402 ........
17:38:40.051169 IP 10.1.10.245.http > 10.1.10.1.43932: S 245310500:245310500(0) ack 522853637 win 4380 <mss 1460,sackOK,eol>
0x0000: 0ffe 0800 4500 0030 27ef 4000 ff06 29ed ....E..0'.@...).
0x0010: 0a80 0aeb 0a80 0a01 0050 ab9c 0e9f 2424 .........P....$$
0x0020: 1f2a 1d05 7012 111c 2a0e 0000 0204 05b4 .*..p...*.......
0x0030: 0402 0000 ....
17:38:40.053644 IP 10.1.10.1.43932 > 10.1.10.244.http: . ack 1 win 64240
0x0000: 0ffe 0800 4500 0028 0a41 4000 4006 06a4 ....E..(.A@.@...
0x0010: 0a80 0a01 0a80 0aeb ab9c 0050 1f2a 1d05 ...........P.*..
0x0020: 0e9f 2425 5010 faf0 7018 0000 ..$%P...p...
17:38:40.053648 IP 10.1.10.1.43932 > 10.1.10.245.http: P 1:416(415) ack 1 win 64240
0x0000: 0ffe 0800 4500 01c7 0a42 4000 4006 0504 ....E....B@.@...
0x0020: 0e9f 2425 5018 faf0 43c5 0000 4745 5420 ..$%P...C...GET.
0x0030: 2f20 4854 5450 2f31 2e31 0d0a 486f 7374 /.HTTP/1.1..Host
0x0040: 3a20 3130 2e31 3238 2e31 302e 3233 350d :.10.1.10.245.
Well you are hitting the virtual server so let’s look a little deeper and expand our dump. Your original client IP is in the first line of the dump 16:44:58.801250 IP 10.1.10.1.41536 > 10.128.10.245.https
In the second SSH window we will do an expanded tcpdump for the sake of interest
tcpdump –i <server vlan name> -X –s128 host <client IP>
Hit your virtual server again. As you can see, we are sending packers to the pool members. They just aren’t responding so we can reasonably suspect it’s a server issue.
It could be a port issue. Let’s check to see if the server is responding on port 80. On the BIG-IP, in an SSH window:
Do a <ctrl-c> to escape out of tcpdump, if you are still in it, and use curl to test the server
curl –i <server ip>
“-i” to dump the HTTP header information also
[root@bigip249:Active:Standalone] config # curl -i 10.1.20.11
HTTP/1.1 200 OK
Date: Sat, 26 Jul 2014 19:25:28 GMT
Server: Apache/2.2.22 (Ubuntu)
X-Powered-By: PHP/5.4.9-4ubuntu2.2
Vary: Accept-Encoding
Content-Length: 3819
Connection: close
Content-Type: text/html
<html>
<head>
<TITLE>Using virtual server 10.1.20.11 and pool member 10.1.20.11 (Node #1)</TITLE>
<meta http-equiv="Content-Type" content="text/html; charset=us-ascii" />
The server is responding to the BIG-IP when directly connected, but not through the virtual server. Sounds like the server is routing around the BIG-IP, which means the BIG-IP is not the default gateway.
Turn SNAT Automap back on the www_vs virtual server
